Question about Vizio VX37L Television
HDMI error/H1005 -hdcp link integrity check failed vizio 32
3 Suggested Answers
SOURCE: vizio 32'' sound off after a few hours on hdmi 1
had same problem, main board issue if sill under warranty they will come out to your house and fix it for free
Posted on May 18, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
Remove banner
Bad HDMI cable. You can't bend it too sharply or pull on the cable. These are fragile.
May 02, 2015 | Westinghouse LD-4655VX 46" LED TV...
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Why am I getting the HDMI Error. Unable to display video(H15005 - HDCP link intergrity check failed?
The hdmi outputs on the uverse receivers are garbage, I recomend using them. Go to Walmart and buy a component cable install it and never worry about the hdmi error again.
May 29, 2014 | AT&T UVerse
Getting a H1005 error
Make sure that the TV is looking at the HDMI plug in the menu. All so make sure you are getting a good connection at the connectors some good contact cleaner will help this you can buy this at radio shack.
Mar 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
H1005 error
I played with going to another HDMI outlet and then back to the original and it seems to quickly reset itself and the message dissappeared!
May 23, 2009 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Non-HDCP Compliant Error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Jan 06, 2008 | Protron PLTV-32 Television
Vizio VX37L Television Logo
52 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
