Question about Radio Shack Audio Players & Recorders
PA Amplifier blows fuses
Radio Shack 250 watt PA Amplifier keeps blowing fuses. This has worked for a year with no problem and one day, while in regular use, blew a fuse. The fuse has been replaced but continued to blow when the power is turned on. The correct fuse is being used (slow blow 7 Amp 250 W). Nothing has been added or removed or changed in any way, just all of a sudden stopped working.
  • 3 more comments
  • Shawna Jordan
    Shawna Jordan Mar 23, 2014
    This makes a lot of sense, however, there are no speakers connected. Once the fuse originally blew we unhooked all speakers and now there is nothing at all hooked to the PA Amplifier. We replaced the fuse and even the smaller internal fuses and only plugged it in the wall alone with nothing attached to it and once the power is turned on the fuse blows...
  •  Grubhead
    Grubhead Mar 26, 2014
    Speaker wires touching will permantely short out the power amp device, even when the wires are touching. The only cure is to replace the faulty device(s) that have shorted. If you are not certain which device has gone look at what is attached to the big heat sink. Each part will have a number on it. You can report them back here. However if you see something like the image below I would replace that as it will have gone.
  •  Grubhead
    Sorry that should read "when the wires are NOT touching".
  • Shawna Jordan
    Shawna Jordan Mar 26, 2014
    I don't see anything like your picture. Everything attached to the aluminum heat box has the same number...5W0..what looks like the omega symbol...22J
  •  Grubhead
    Grubhead Mar 31, 2014
    The devices are I think "N-channel power MOSFET" . One or more could have gone. You could try an Ohm meter across the terminals of each device. It's quite possible the short will show up on the faulty device. It will be just like you have touched the test probes together. The 1K setting on the Ohm meter is best for the test. Without seeing a picture of the device I can't say what part number it uses. My best guess would be the 22J being the part number. Possible 2SJ 22 (?) But you will have to do some research on it. If you find one that is faulty you could remove it and take it to an electrical parts shop who might be able to help track down a replacement.
  • Radio Shack Master
  • 5,444 Answers
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Posted on Mar 23, 2014
Thumbsmagee
SOURCE: peavey classic 50/50 keeps blowing fuses.
Rob,
I have a classic 50/50 as well and re-tubed it with JJ el84s, vintage teslas and mullard 12at7s. As long as you replaced it with EL84s, I can't imagine that the output would be increased enough to damage the OT. When I got my 6505 Combo, one of the 6L6s was bad, and it kept blowing fuses and howling like a banshee. I would think that an OT problem would result in a significant loss of output...or none at all. I've gotten DOA tubes from a few places. I would suggest swapping each tube out 1 by 1, until you find it...if that is indeed the problem...before you pay the cash to have it worked on.
Posted on Oct 29, 2007
SOURCE: amp blows fuses
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Posted on Nov 03, 2007
  • 16 Answers
SOURCE: my bass guitar amp is blowing fuses
Hi ! I have a soluution and it is about to be published on http://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
Please check in a few days time
Posted on Dec 04, 2008
  • 54 Answers
SOURCE: Carver M-1.5t amp. blows 15 amp fuse.
First off....you didn't say if you are a tech or not. I'll make this really simple.
If you are not a seasoned tech with experience solving carver problems....you will waste tons of time and money guessing what the problem might be.
Carvers are quite the unique beast. They deliver whopping amounts of power in a small chassis. This is done by using a trick switching power supply. There can be any number of possible problems.
To properly diagnose this you will need an oscilloscope, signal generator, variac, and of course a really good quality multimeter that can test diodes and transistors.
IF and only IF you are a seasoned tech with all the above equipment, that has no experience repairing carver, then go online to ebay, find member techman777, and for around $15 you can get a nicely reprinted service manual. Troubleshooting expertise and the manual will take you foreward from there because the manual has a very thorough troubleshooting guide in it.
If you think you can fudge your way through the guide without any serious electronics knowledge, you are in for a rude shock as you will find that you are an earth man trying to read martian.
If you are just a casual fix it guy ( nothing wrong with that !!! ), I strongly suggest that you do NOT make this your first try at fixing an amp.
The value of these, in mint condition, all rebuilt is around $350- $450 on ebay all day long. if you are willing to invest that much, you can look up carver audio repair on google and send it off to them, as they are reported to do a nice job. OR....you can look me up on ebay, send it to me and I will do a nice job too, and that comes from 20+ years of repairing.
I know that this isn't much help, but carvers are very special, and require special knowledge to repair.
Best of luck.....Rob
Posted on Dec 16, 2008
petraman7
  • 1175 Answers
SOURCE: When I turn it on the fuse blows up.
Hi..
It will need service.
I would call the music store closest to you that sells PA gear and ask who fixes theirs.
Posted on Jan 12, 2009
I need to reset a power amplifier. i have a 250 watt power amplifier from radio shack. i thtink that one of the wires touched or someething either that or the power was on for too long. but now the p
One important note to be aware of Polarity. DC connections are Positive + and Negative -. RED/Black and/or White wires. Yellow is usually Video. Do not Reverse the polarity as this can cause mismatches and/or short circuits. Disconnect your attached wires and re-attach them correctly and firmly. Wires must be set into or onto the posts or connection points correctly by + or - and they may not touch one another. Check the Reset or Fuse on the amp and make certain you have full power.
If you fail to polarize correctly, you could damage the speakers moreso than the Amp.
Jan 07, 2014 | Radio Shack 250 Watt PA Amplifier...
I just purchased a 250W Radio Shack PA amplifier. Everything seems to work fine but I can't figure out how to connect a an auxiliary device or CD. There is only one jack for CD/AUX and whatever I...
I had this problem to the only stereo rca input I could find was the top red and white. Everything else is mono, I'm currently working with 1.so if you have any advice please let me know.
Nov 15, 2013 | Radio Shack 250 Watt PA Amplifier...
One side of speaker terminal doesnt work o the amplifier
It's possible this has two fuses. Check to see if either is blown and reset/replace. If not, then the "channel" (side) that won't work has been damaged and will be difficult to replace.
Sep 17, 2013 | Radio Shack 250 Watt PA Amplifier...
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
How i can install external page port of a pabx Norstar with output of 600ohms to the input Radio shack 250 Watts PA.
Connect Nortel PABX external page port output to the amp input.
Either by phone plug or RCA connector, any of the two will work.
Apr 19, 2011 | Radio Shack 250 Watt PA Amplifier...
Can a radio shack 250 Watt PA Amplifier work on musical instruments like a guitar and keyboard?
Yes. It won't be great, but if you're starting out you should be ok. Musiciansfriend.com has some of the more popular pa options - generally radioshack=bad.
Dec 28, 2010 | Radio Shack 250 Watt PA Amplifier...
Radioshack 250 watt pa amp stopped making sound
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Radio Shack 250 Watt PA Amplifier...
184 people viewed this question
Top Radio Shack Audio Players & Recorders Experts
 Grubhead
Grubhead
Falling star
Stuart Slabber
Level 1 Expert
Are you a Radio Shack Audio Player and Recorder Expert? Answer questions, earn points and help others
