Question about Tour Trek One Click 2.0 Collapsible Push Cart
The 2.0cart pules to the right i need to know if there is an adjustment to make the front wheel turn in a straigh line
How do you adjust the front wheel to turn straight and not pull to the right
Greenfield ride on mower front axle/wheels
zYou are correct. there is an adjustment for the wheels. The front wheels are connected to the steering by tie rods, as in a car. This kind of adjustment is not found in a user manual, but you can do it. Inspect how the wheels are connected and inspect the tie rods. The tie rods have to be disconnected from the wheel and turned in or out depending on which direction the wheel needs to go ,in or out. One tie rod is right hand thread. The other is left hand thread. So the adjustment is making the tie rods shorter or longer. If you do a search on the web ' riding mower tie rod adjustment', you'll find plenty of info.
Good luck
May 04, 2014 | Garden
Brake pedal
Did you ensure that the master brake cylinder was topped up properly whilst you bled the back brake shoes?
If you did so and the brakes are free of air in the lines, then you still have to adjust the brake shoes to their operating position. Secure vehicle from movement. Jack back wheels of the ground, support with jack stands. Remove the rubber grommets that covers brake adjustment wheels. Turn star wheel adjuster with special adjustment tool or a wide blade screw driver. Lock the wheels with the adjustments, push in brake pedal until you have pressure, back off adjustments until wheel runs freely. you should have plenty of pedal now. Make sure master is at the right level at all times.
If you don't have pedal now then I would suggest you still have air in the brake lines.. If you pump the brakes until you have pressure and the pedal feels spongy , then you still have air in the line somewhere. Bleed until air is removed.
Mar 21, 2014 | Isuzu Rodeo Cars & Trucks
Front wheels not turning in 4wheel drive 1996 dodge dakota
Check and make sure the transfer case is adjusted right If the front end was broke you would know it. Jack up one front wheel and put it in 4wheel drive but not lock and see if the front drive shaft turns if it doesn't you need to adjust linkage or if it's electric make sure the signal is getting to the transfer case. If it only locks front and rear jack up one rear wheel also and do the check. Most people with 4 wheel drive don't know they have two wheel drive One in the rear and one in the front unless you ordered a locking dif from the factory they don't come this way. Then you would have 3 wheel drive
Dec 02, 2011 | 1996 Dodge Dakota
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
I replaced all 4 brakes on my 98 chevy malibu. for some reason i am not getting pressure back. but am being told i dont need to bleed the brakes. should i anyway. or could the adjusted on the rear drums...
Both air in the brake lines and rear drums too far out of adjustment will cause the pedal to go to the floor repeatedly.
Bleed from the wheel that's farthest away from the master cylinder first, typically driver's side rear. Then bleed the others, ending with the one that's closest to the master cylinder. Generally, right rear, left rear, right front, left front.
Adjust the rear brakes until you hear them rub a bit as you turn the wheel, then back off a couple of notches. Be sure to use the brakes when backing up at first, let them adjust themselves up to where they should be.
lp
Jan 09, 2011 | 1998 Chevrolet Malibu
I would like to know how to adjust the stove so that it sits level ?
Most stoves of this type have both wheels and screw adjusted levellers (generally in the front only).
The lower drawer opens to reveal these in the corners or a loose clip-on front panel needs to be removed by gentle pulling. The knurled wheel like knobs are generally turned anti-clockwise (Right to Left as you face the stove) to screw out and thereby lift the stove front up to suit your requirements. Good Luck.
Sep 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How to adjust my til tof my 10
When you are facing the saw as if you would be operating, there are two adjustment wheel on the front and right hand sides of the saw cabinet. The front wheel adjusts the blade height, the wheel on the right side of the cabinet adjusts tilt. Each of these wheels are equipped with a locking nut, a smaller wheel in the center. this must be loosened before any adjustments can be made and should be tightened before operation. If there is significant resistance while trying to adjust either of these it may be a result of misaligned gear or excessive buildup of dust and shavings on the gearing.
Feb 14, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Hi i would like to know if i can manualy do a wheel alighnment? If yes can you plaese tell me how? I have an 1989 f250 straiht6 fuel injected
short of abuck ?first jack up the front end ,put 2 chalk marks on each wheels opposite to each other across the wheel ,take an exact measurment,with a string line or an adjustable rod .between the chalk marks both front and rear, if you are running on radial tyres ,then the two measurements need to be the same, if you are running on crossply tyres the front of the tyres ,need to be half an inch narrower than the back .adjustment is made by loosening the clamp bolts at both ends of the track rod rotate the rod and you will see the distance change so you will know which way to turn it . now for the bad news ,you have a ford turmoil front end which i believewere not spposed to be released until we had a hell and they were supposed to be punishment for our misdemeaners on earth, so you dont jack the front end up first ,take your measurements with a little weight taken but not enough for the tyres to move, the rest is the same except you hve to jack it up to make the adjustments ,and then tak it for adrive ,come back and start all ofer just to check it .continue doing that until you have it right good luck! you know i realy dnt know why ido this---- just thinking about it pissesme off.
Dec 06, 2009 | 1989 Ford F 250
Sloppy steering 96 Ford Bronco
You need to check all of you front steering components have someone turn the steering wheel back and forth. While you lay on the ground check all joints and components for play then check your steering shaft under the hood see how far steering wheel moves to each directions to when your tires start to move your gearbox has an adjustment on it that can be adjusted it looks like a screw with a nut at the bottom loosen nut a few turns and hold it with a wrench then take screwdriver and turn screw about 1/4 keep checking wheel for play you can tighten to much so keep checking that wheel turns back when you let go if you have any loose joints undernieth replace that part
Jun 22, 2009 | 1996 Ford Bronco
Cabrio 1997 brake shoes (rear) adjustment
There should be a rubber insert in the back of the wheel assembely,take it out and you can adjust the brake tighter or looser by turning the adjusting wheel
Jan 15, 2009 | 2002 Volkswagen Cabrio
Tour Trek One Click 2.0 Collapsible Push Cart Logo
159 people viewed this question
Top Tour Trek Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Tour Trek Golf Expert? Answer questions, earn points and help others
