Question about Eureka Vacuums
Vacuum doesn't slant backwards
I pushed the foot thing on the vacuum to slant it so I can vacuum but it seems to be stuck, would appreciate any help or solutions anyone has tried!
You have to click the switch on the bottom to the cleaning unit and it will lay backh
Posted on Mar 21, 2014
3 Suggested Answers
  • 6 Answers
SOURCE: Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Posted on Nov 12, 2008
WonderTech
  • 268 Answers
SOURCE: what pedal do you push to slant the start handle backwards
Here is a link to the owners manual.
http://www.eureka.com/servlet/ListParts?model=4870&description=Bagged+Upright&type=Upright
Select your model and then select owners guide.
Hope this helps.
Posted on Aug 31, 2009
Renting a condo and cannot get the vacuum out of upright position so that I can vacuum. It is a DC17 animal absolute. Thank you
Hold handle backwards at 30 to 45 degree angle and press front edge of base with foot, there are two indents for foot, 1 on each side. You need to make sure that the hose moves forward so that it will collect from the brush. Hope this helps
Feb 13, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
New carpet is very thick. Hard to push vacuum. Is there an adjustment to allow more air?
Your vacuum should have and adjustment for the "depth of pile" of the carpet.
If it has no such thing at all, ( a few do not,) one solution is to pull it backwards slowly instead of pushing it.
It should clean forwards as well as backwards for you.
God bless your efforts.
Jan 03, 2017 | Vacuums
My Dyson falls backward & won't stand up - what's wrong?
Hi Kay,
I'm sorry to hear you're having difficulty with your DC18. If the stabiliser doesn't seem to be locking the machine upright, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will be useful if you can have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC18 all floors Bagless Upright...
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
Pushes hard over the carpet and left lines in the new carpet. My father pulled it backwards and seemed OK. It just pushes extremely hard forward. The Dyson is about four years old and have not had any...
Check the axles of the wheels for debris accumulation. Also, make sure the height is set for the type of carpet that you have. Try pushing the machine on a bare floor--is it hard to move there also? Hope this helps!
Nov 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Program not working
i had the same problem. there are 2 little metal discs that are sensors. have you tried cleaning then? you need to remove the brush and roller and they are right there. very sensitive. i used windex on a rag ,put it together and it has worked ever since
Feb 23, 2008 | Roomba Pro Elite Bagless Robotic Vacuum
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
20 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
