Question about Kenmore Kitchen Ranges
911 41089991 Door will not close tightly
    Master:
  • 560 Answers
If there are no obstructions causing this, the problem is likely the springs or their connection to the oven frame. Sometimes they break and sometimes they fatigue due to the heat and sometimes they were under sized from the start. You can buy replacement springs(and associated mounting hardware) from the manufacturer or third party vendors.
Posted on Mar 19, 2014
Driver door on my 1997 Lin Towncar will not close tight un less a windown is cracked open ( any window). What is my problem?
The latch striker may be adjusted just a bit too tight. What is happening is that when you attempt to close the door, the air pressure inside the vehicle resists the door closing. That is why opening a window solves the problem. There is no back pressure to fight the door closing. If the latch is adjusted properly, then you just need to put more oomph into closing the door.
Mar 02, 2015 | Cars & Trucks
Regrigerator door not closing tightly
ither door seal is the problem if is out of alignment have to replace shims, have to remove door for this
Jan 28, 2014 | Amana Refrigerators
Door wont close tight
The hinges may have to be loosened to realign the door to close evenly
Feb 01, 2013 | Haier Refrigerators
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Side cargo door does not close tight. How do I adjust it?
on the frame of the car you have a catch undo the adjuster screws so that they are pinch tight, but not too tight ,then close the door hard,if you have adjusted it correctly you can then do up the screws tight.keep opening/adjusting till you get it just right.....
Aug 27, 2010 | 2000 Ford Econoline
Door not closing, bouncing back up when reaches sensors
IF THE SENSORS ARE MOUNTED TO THE TRACK THEY COULD MOVE OUT OF ALIGNMENT WHEN THE DOOR CLOSES. WATCH TO SEE IF THE LED LIGHTS ON THE SENSORS GO OFF AS THE DOOR CLOSES.
THE TRACK COULD BE TOO TIGHT CAUSING THE DOOR TO REVERSE WHEN IT BINDS.
IF THE DOOR IS TOO TIGHT WIDEN THE TRACK AT THE FLOOR. YOU MAY NEED TO CHIP CONCRETE IF IT IS CAUSING THE TRACK TO BE TIGHT.
HOPE THIS HELPS
May 11, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Kitchen Ranges Logo
32 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
