Question about Kenmore Washing Machines
El1347360 control boardHello I have a Kenmore C47072 it stopped doing the final hi speed spin my wash have been soaking wet. I went a head and did all the diagnostic test all 9 and came up with the er
Diagnostic test all 9 and came up with the error 43
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Posted on Jan 08, 2009
  • 1525 Answers
SOURCE: I have a Frigidaire LTF2140ES1
hello doug just looked a error code e43 board communication problem
shaun
Posted on Jan 16, 2009
SOURCE: spin speed too slow
CHECK THE PUMP. I had the same problem and after removing the pump (fairly easy) found a clump of stuffing from a hole in a quilt jammed in the impellor. After removing and installing the then cleaned out pump it worked perfectly. Suggest using a regular stainless steel hose clamp in place of the factory clamp that is hard to put into position on the hose to the pump. Be sure to put the clear plastic bag back in place over the pump assembly to protect the pump from water damage.
Or the  stater motor on the back has lost a phase because one of the windings has shorted. If the cycle sounds normal and it doesn't sound like it's struggling then the problem is probably not going to be related to the motor. I've found most of these cases to be related to the control board itself.
good luck
Posted on May 05, 2009
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
jesiquiux
  • 168 Answers
SOURCE: Kenmore 44052 will not spin. Replaced door switch
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Posted on Sep 30, 2010
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
It is a much older style washing machine. I put a load of clothes in then went to switch the load and i realized that they were soaking wet. The spin is not working.
Check the spin belt and the relay that engages it. Also make sure that your time is going to the spin cycle and not stopping short of it. If your machine has a two speed motor which goes into high speed for the spin, this might be defective.
Feb 03, 2011 | Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Jan 07, 2009 | LG WM-1832C Front Load Washer
Drum speed slow on final spin
what waher is this and what speed is it
Dec 05, 2008 | Kenmore 46462 Front Load Washer
Clothes are still soaking wet when load is finished.
Have you tryed replaceing the motor speed control. That is also what makes the machine spin.
Sep 24, 2008 | Kenmore Elite 45986 Front Load Washer
Final spin speed
unplug unit for about 2 minutes this will reset the computer if not inside the lower front panel SHOULD BE a tech sheet this will tell you how to put it in diag. mode and will tell you whats going on with codes and this tech sheet will give you the meanings
Dec 21, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
