Question about Yamaha Dtxpress Iv Special Electronic Drum Set
Hi-Hat not always working with controller
Hi-Hat controller works for Dad and Brother but not for me! But even they have to press down hard................? Is this right, how can i solve this........? Thanks
  • Anonymous Mar 31, 2014
    The hi hat makes a closed sound when I have not pressed the hi hat control pedal
  • 69 Answers
Youll need to change the sensitivity on the brain and all will be good
Posted on Jun 23, 2009
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
Dtxpress ii
Open pedal, check with Ohm Meter when you open/close it at the connector.
Fix.
Sep 27, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi. I've got a problem with my hit hat controller with my Yamaha DTXPRESS III special. It is still opened, even if I strongly push on the pedal. But, when I half plug the jack in the hit hat controller it...
Sounds like the internal switch in your pedal.
Get an OHM meter, and check the continuity when you press and release pedal. Should change from Open to Short.
If not, take it to a Tech.
Nov 08, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Where does hihat control cord go
The hi-hat trigger goes into trigger #1. Using a footswitch will change the hi-hat trigger sound to a closed hi-hat. On page 8 of the user manual is the list of triggers and their assignments. Note that some new triggers from newer drumsets use TRS cables because they have two sensors within the drum head... Often the new ones have a rim shot snare trigger as well as a trigger for the mesh head. These newer different brand triggers would require special cables to be made to attempt to use them with the DM5. The DM5 is older technology now but is still useful.
Jul 25, 2011 | Alesis Dm5 Drum Module 18 Bit
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
I have a problems with my HI-HAT control. When I put a pedal for HI HAT controler down, you can play HI HAT, but in the next 20 second the pedal not choke HI HAT cimbal...What can i do? Thanks
Verify that the pedal is the CORRECT type for what you are using it for.
Pedals came in MANY varieties. I would ask the store where you got the items about it.
Pedals can be switch type either normally open or closed, Variable resistance/volume control, pulse type like the kick drum pedals that generate a varying trigger pulse...
My hihat controller has a problem sounds become
Make sure you aren't mixing up the cord for the hi hat pad and the hi hat controller.
Jan 17, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
302 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
