Question about Singer Sewing Machines
Singer 7033 stitch balance ring will not turn
Will not zig zag stitch , balance ring will not turn
night71
  • 328 Answers
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
Posted on Nov 01, 2007
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
WonderTech
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
  • 980 Answers
SOURCE: Singer Fashion Mate 257 won't make a zig-zag
You may need to retime the machine, email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Nov 14, 2009
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
On a singer machine from the 70's, how do you change it from sewing zig zag to straight line?
Most likely you change the stitch-width selector to straight, otherwise it will stitch in varying degrees of zig-zag.
Jul 07, 2017 | Singer Sewing Machines
Why won't my singer curvy sewing machine zig zag stitch?
there could be something wrong with the cam that makes the zig zag stitch.
Jan 22, 2016 | Singer Sewing Machines
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Need to know how to the zig zag stitch on the 132 featherweight machinge by singer.
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Mar 04, 2009 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
69 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
