Question about Necchi Sewing Machines
Word a word that means to hurt or destroy something that is three letters
    Sergeant:
  • 333 Answers
Hello Hikaru, How about "MAR" ?
Posted on Mar 21, 2014
Singer 237 M A. What does "M A" mean? Serial number ME 168926.
Hu singer used specific letters to indicate where the machine was made. eg K=Kilbowie Scotland G=Germany MA= Italy
Feb 27, 2014 | Singer Sewing Machines
How can I program a full name into my 1+Husquvarna Sewing machine?
I have the #1 and it should be similar in programming if not the same.
Instructions for the #1 (1200) -- Programming Block Letters
(one model down from the #1+ Husqvarna)
From the machine instruction page for letters and numbers
Ready:
  • .Fabric Woven-medium, stitch & tear
  • .Enter: Woven-medium on your sewing advisor
  • .Consult Info display: Presser Foot B
Program:
Insert Cassette B
  • .Touch SELECT function to PROG
  • .Advance to an empty memory
  • (->) means arrow: .Touch H-> U-> S-> Q-> V-> A-> R-> N-> A (STOP) -> REP
Sew:
  • .Place Stitch & Tear against the wrong side of your fabric.
  • .Stitch the word HUSQVARNA. Easy!
  • .Now, program your name and today's date. Stitch on your sample.
Smaller sizes of letters
You can program a number of letter sizes by - the width before entering the letter. You may want to enter the first letter of a name at 6.0 width and the other letters narrower.
Correcting Errors
You may clear any single stitch but the first one on a program. When the cursor is under the first stitch and you touch CLR, the entire program is erased.
NOTE: The cursor designates the first letter to be sewn.
Oct 15, 2011 | Husqvarna Viking 1
My 7570 has a blank screen when I turn it on it is lit up nnothing comes up.
There is a small wheel below the buttons on the right hand side that can be turned "up" or "down" to see the electronic letters properly. Sometimes that gets bumped accidentally and the screen appears to go blank - it's still there, just needs to have the letters darkened - they are just washed out. Turn the little wheel and it should return. If that doesn't work, quite possibly there is something else going on. If you can stitch even without seeing the screen - that most likely is the answer. Good luck! S
Apr 19, 2011 | PfaFF Creative 7570
Singer 3270c stops sewing in the middle of sewing and doesn't start up for a while
How is your power cord? Has it been stored wound tightly? Take it in for service because it may overheat and destroy the machine. I hope that it is under warranty or that it won't cost you anything to diagnose it, but something is very wrong.
Apr 16, 2011 | Singer 7462 Mechanical Sewing Machine
Photo on how to install bobbin & case holder, held in by three stamped out metal brackets and three screws.
Go to www.singerco.com and under support, pick instruction manual, then put your model number in the box, no letters only numbers, then download your manual for free. Good luck
Sep 20, 2010 | Singer Sewing Machines
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Designer SE - My lettering looks terrible - jagged and twisted.
This may be your stabilizer. What kind are you using?
A good, solid foundation is important. If the fabric is allowed to stretch or move your embroidery will always be poor. Sweatshirts require considerable stabilization because they are very stretchy.
If the sweatshirt is a high loft fleece you may also want a stabilizer on the top of your fabric.
Try stitching the same letters on a piece of cotton fabric with a heavy tear away or cut away stabilizer. If it looks okay on that, it will look okay on the sweatshirt once it is stabilized.
May 08, 2008 | Husqvarna Designer I
Ebroidering two llines
I don't think you can do 2 lines of text in the computer of the machine. If you have a software program that allows you to do lettering, you can do 2 or more lines. I haven't found anywhere in the instructions that really helps with lettering stored in the machine. I purchased Embroidery Magic 2 for $98. It is a powerful little program for the price and comes with 5 fonts. Also does manual digitizing (which I haven't really figured out yet). Do you have PED Basic to downloand designs from your computer to an embroidery card? If so you can download many free designs and purchase lettering at very good prices on many sites. Just remember that lettering purchased from the web doesn't not mean it is a keyboard font and you will need to combine letters to make words (treat each like a separate design). Maybe this will help.
Dec 05, 2007 | Brother SE-270D Computerized Sewing...
Using my monogram machine
The one thing I've found is that when using the fonts stored in the machine, you need to treat each as a separate design. Then you would change the size of the Center Letter. I, too, wish the manual was more instructive. It is much easier to use a separate software program where you can create lettering and monograming. Do you have PED Basic, the program that allows you to download from your computer? That is a very good investment (about $150) and you can get free designs and download purchased lettering from different web sites. There is also a good site www.embroiderydk.com where you can join for a small monthly fee and create lettering and monograming. You also have access to over 7000 designs that you can download free whenever you want. It is well worth the price of $9.00 per month and you don't have to be limited to a bunch of emboidery cards or just the built in designs on your machine. One final idea...go the Brother.com and request more instruction on the embroidery portion.
Jul 05, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
24 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
