Problem with avantra 25 imagesetter using takeup cassette where the error message keeps stating media in cassette when there isn't what can be done to correct this please
An error message keeps appearing that there is media in the takeup cassette when it is empty and won't allow to proceed to the next stage is there a way of overiding or correcting this preceedure please
  • Graham Beswick
    Graham Beswick Mar 18, 2014
    Sorry this is a problem with Agfa film imagesetter avantra 25 not a scanner
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
  • 4 Answers
SOURCE: I keep getting the same message while using autocad 2002lt
There are a few things to try. I'd try this first: Start ACAD and use the Recover command (File menu) to open your drawing. If that doesn't you can insert your drawing into an empty drawing as an exploded block and/or purge your drawing.
Posted on Dec 20, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Muzzi_123
  • 749 Answers
SOURCE: trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
Posted on May 19, 2009
Error 01 carriage jam on avantra 44s what can i do?
MAYBE THE CARRIAGE IS FAULTY.DID U TRY A NEW ONE
Nov 19, 2013 | Panasonic Workio DP-4530 Copier
I have a Canon Pixma 640. It's hardly been used since I bought it. Now suddenly there is an error message saying 'Error cassette, no paper, please load paper and press OK' I've done this...
This may sound patronising but are you sure there is paper in the cassette located at the bottom of the machine and not just on top at the back. There is also a button on the operation panel that selects which tray you are using. It could be as simple as that!!
May 26, 2011 | Office Equipment & Supplies
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
Agfa imagesetter 1000 plus, the error messege is LDM ERROR. What does it mean ? What is the potential cause or effect ?
Jan 18, 2011 | Office Equipment & Supplies
I have problem with an ir-2230 copier error code e000110-000
A Canon copier, eh? Low numbers like that sound like open chassis issues but might be a status you can clear (see link below.) Canon has software for it including online manuals you can install so you can find the error/maintenance code index. Meanwhile you can just reset the copier and make sure it has toner, paper, and a securely closed media door.
Try:
imagesetter error-code-reset
Jan 05, 2011 | Computers & Internet
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Canon mp830.can't print from cd cassette i get an error: close print door first
Make sure the driver has the correct media selected. You may have to select a "tray" to print from. This may be done using a button on the control panel, using the menu and LCD display, or by setting the software driver preferences.
If that does not solve the problem try deleting and reinstalling the driver. Don't forget to check the owners manual. It may have information on this problem
Nov 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Help!!!! Windows Media Player and ISS problem
Do you have an exact error message by any chance?
Sep 30, 2007 | Intel Anypoint Network Adapter
k24674
jasbo
jasbo
