Question about Dell Vostro Computers & Internet
Samsung 40 lcd tv ln40c530f1fxza
When i connect laptop to TV with a HDMI cable, Computer display appears on tv for a few seconds and then tv goes black, Audio continues to come through TV. The laptop has Win 7 pro 64 Bit OS. What could be the problem? TV is not part of the Homegroup
  • Phillip YS
    Phillip YS Mar 20, 2014
    I changed the resolution, but this did not work
    Top Expert:
  • Dell Master
  • 25,763 Answers
Check the video resolution is not too high for your TV.
Posted on Mar 18, 2014
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
  • 12 Answers
SOURCE: i want to connect my samsung NC10 laptop to my TV
has the tv got pc/vga in ? also doseur pc have s/vid out
Posted on May 18, 2009
tknalty
  • 121 Answers
SOURCE: How do I get TV to recognize audio from laptop....
Try the following:
1. Select System Preferences from the Apple Menu.
2. Select the Sound icon.
3. Click the Output tab at the top of the window
4. Highlight the option that is not the Internal Speakers.
5. Make sure the Output Volume is not set low and that the Mute checkbox is unchecked.
6. Close the Sound window. (via Red Radio Button, Top/Left of window).
Try it again and see if you get sound this time.
I hope this helps. Regards,
Posted on Feb 09, 2010
candy1986
  • 340 Answers
SOURCE: I am trying to get
you need a converter to convert the VGA analog to HDMI digital signal
Posted on Mar 09, 2011
  • 11800 Answers
SOURCE: Try to connected my laptop
Your tv doesn't supports the resolution the laptop is sending it . To fix that select in the display settings a lower resolution before clicking Apply - use 1280×1024. After that (once the tv is working) you could try to use higher ones.
Posted on Jun 12, 2011
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Jan 02, 2014 | Samsung SyncMaster 400PX 40 inch LCD...
How can I hook my my sharp LCD TV up with my desktop computer without a monitor to change the settings on my my computer. I have both HDMI cable and VGA cable. When I turn my computer on no picture pops up...
Try to reset your computer BIOS - open your CPU, plug off the power, remove the battery in the motherboard then put it back after 20 seconds.
Plug the VGA cable to your CPU and connect it to your LCD TV. Try ro open your CPU, there should be display on BIOS bootup.
If the display goes out before windows startup, the resolution settings on your computer is not compatible with your LCD TV. If this occurs, hard reset your CPU then press F8 simultaneousely until new display appears, then select safemode. On windows safemode, adjust the resolution settings compatible with your LCD TV.
Jun 28, 2013 | Televison & Video
Acer lap top to Samsung plasma
Depends on what type of ports your HP has and what type of ports your Samsung TV has. The easiest connection is to try to connect using the ports that they both have. Otherwise, if they have different ports then you will need some type of converter that goes between the two of them to make them communicate.
Most computers have a VGA port, does the Samsung TV have a VGA Port? New computers have a HDMI port, does the Samsung TV have a HDMI Port? If so you the connections that are alike or you will need a converter.
Once you have them connected, you just have to select the Input on the TV. Most times if you use VGA then you select PC or Computer as the input. There should be an HDMI input selection if you use HDMI connections.
Reboot the computer and the display might appear on the tv. If not you will have to hit some keystrokes to toggle the display between the computer and the tv. Most times on the computer you will hit the FN function key and one of the F1 thru F12 keys that controls the display on an external. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display. Press and Hold the FN function key then hit the correct Function key (F1 thru F12) that toggles the display.
Apr 07, 2012 | Computers & Internet
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPad® T61 PC Notebook
Connecting my laptop to my tv via hdmi
The first step is to determine whether the computer, the HDMI cable or the TV is the faulty link in the chain. I know it's a tremendous hassle to try a different TV, different computer, etc. But it will at least narrow the problem down to one component. My guess is that it's something in the computer that needs reconfiguring; that would be the most likely scenario, assuming you have a new HDMI cable.
Dec 27, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Alun Cox
