Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
This machine prints 2 blank sheets and jams on the third blank sheet every time i make a single copy of a LTR size piece of paper. I have just installed a new drum and programmed the paper size as LTR and plain but now sucess
  • cevdem Dec 12, 2007
    waiting to receive fax. It should fax was received it never printed, now it just says printing on the screen but nothing is happening. Have reset printer by powering of and have also reinstalled printer to computer
  • bourgois Dec 19, 2008
    mY brother mfc-8840D prints 2 blank sheets and jams on the third blank sheet every time i try to print something or copy anything.
Frozen Keypad on Brothe rMFC-8440 All-In-One Printer
Posted on Jul 31, 2008
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Posted on Jul 12, 2008
How can I remove a paper jam from under the fuser bar in Brother MFC-8440?
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Oct 27, 2015 | Brother MFC-8440 All-In-One Laser Printer
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How can i make double sided copies on a brother mfc 7420 printer???
The manual doesn't say it will do double sided copies. it will copy two pages to one sheet of paper or 4 pages to one sheet of paper. you will probably have to make a copy of the document and then reload the paper back into the tray. experiment with it like put it in face down or face up then which is the top of the page. you can use a marker on a blank sheet of paper to see how it prints out.
hope this helps
Jan 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
206 people viewed this question
James Cagle
James Cagle
Jim Keysor
