Question about Panasonic Televison & Video
Part number What is the part number of the power supply board and does it has an equivalent part number?
  • Official Brand Answer
  • 350 Answers
All available parts can be obtained by visiting www.Panasonic.com/parts. Parts Ordering
Posted on Mar 21, 2014
47 LG tv with blown power board - need to identify replacement options
https://www.ebay.com/itm/Vizio-0500-0412-1000-Power-Supply-/292401650643
Feb 12, 2018 | LG Televison & Video
Where can I get a power supply regulator board.
You will need to do the following. Every TV is different and no one guess it for you.
1. Note down your TV manufacturer name; Model number; Serial #
2. Place the TV on the Bed upside down and remove the back cover with correct ***** driver.
3. Identify the power board and look for the symptoms like blown capacitors etc.
4. Note down the board number. Take a pic and seek help to identify if necessary.
5. Google and research site like
TV Parts LCD TV Parts Plasma TV Parts TV Repair ShopJimmy TV Parts Rear Projection Plasma Big Screen Satellite LCD TV Parts TV Repair Parts eBay Samsung Television Replacement Parts Accessories
6. Some websites suggest equivalent part codes too.
Apr 07, 2016 | Televison & Video
Part number of power supply board
Please tell us your model and we may be able to help.
Mar 18, 2014 | Zenith Televison & Video
Acer Aspire 5315-2153 intel celeron board with burn't power Ics.
Are you serious, you want fixya' to supply ic chips to you, not possible, contact Acer support and they may be able to supply the part numbers for you to be able to purchase them.
Dec 30, 2013 | Computers & Internet
My proscan tv has the blue light but wont turn on
Most likely it's the power supply board that went out. (part of it still works is why you get the blue LED when you plug it in.)
If you decide to try to fix it yourself, BE CAREFUL! The power supply board has capacitors that can hold high voltages for many hours after the TV's been unplugged.The equivalent of sticking your finger in a light socket.
You'll need the part number off the power supply to get a replacement.
May 31, 2012 | Proscan 42LA45H 42 in. LCD TV
Hi, I need a new power supply for my Mac G4 Model M7892LL
Your machine is a "Gigabit Ethernet" model PowerMac G4.
The power supply for this model is 661-2332 or equivalent. It has a 22-pin connector.
May 13, 2010 | Apple Power Mac G4 Desktop
Philips hts3555 dvd player has no power
I just fixed an HTS3555/37 with a no power problem. As one person mentioned, you can hear a ticking sound.
The problem is a diode/rectifier on the power supply board. There was no identifiable number on the board for the part, but it's located just above the "T" in the word "TYPE" in the silk screen notice on the board stating "...REPLACE WITH SAME TYPE FUSE". The original part is an HER104, but I suggest replacing it with a larger diode having 400PIV and 2A rating. I used a 30D4, but any equivalent diode could be used. Proper polarity for the diode is silk screened on the board.
To fix this successfully you should to have some soldering and general electronics repair know-how. Caution: There is in excess of 300V on the power supply board even in its non-working state.
Nov 14, 2008 | Televison & Video
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Had a power outage, acer monitor will not power up
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Jan 03, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Televison & Video Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
