Question about Kenmore HE2 Plus Front Load Washer
Have a kenmore elite washer f35 fault code help!!!!!!!
Washer, kenmore elite fault code 35 help!!!!!
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 517 Answers
This is to do with a pressure switch ..take the pipe of and blow in to it ..then blow into the switch..put together..and put on rinse a few times...ifstill the same change the pressure switch
Posted on Mar 19, 2014
  • Mazz Russell
    Mazz Russell Feb 02, 2015
    The switch may be fine.All my problem was is the little hose coming from the p.switch had worn and had a hole in it.Machine keot filling.Just buy a new hose save you a lot of money.
  • 27 Answers
Bad pressure switch. It is mounted on the rear right side under the top. It's a cinch to replace.
  • 44 Answers
SOURCE: F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Posted on Jun 10, 2009
bschilz
  • 2049 Answers
SOURCE: FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Posted on Nov 08, 2009
Testimonial: "Very quick answer.......even better was it solved the problem. Thanks"
SOURCE: My Kenmore Elite HE5t washer flashes SUD
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Posted on Jul 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
craig6773
  • 116 Answers
SOURCE: We keep getting an f35
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Posted on Nov 26, 2010
Kenmore Elite model 42934. Problem washer only
Jul 26, 2010 | Kenmore 42822 Front Load Washer
I have a kenmore Elite...F35 keeps flashing..what does this mean. Please help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(&^%#
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F35
f 35 is not in my info book . if you remove front panel 3 screws at bottom . inside there is a tec sheet with the fault codes. i would ck the clean out for the pump . it is right in front when panel is off . this may solve your prob .. .. mm
Nov 22, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have a similiar problem except the code is F35. Can anyone help
f-35 code is a problem in the pressure switch. the washer thinks its full of water and will not unlock the door replace the pressure switch which is under the top panel and the part # 8181695
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
Code "F 35" What does this mean?
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
74 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
