Question about LG Flatron F700B 17" CRT Monitor
\My RGB colour settings is not configured correctly. i restore fectory but i not helo me so please tell me inwahtamount or values i can reset my rgb colours.
LGFLATRONL1750S
    Habit-Forming:
    New Friend:
  • 130 Answers
Try to emulate 9000K by your personal opinion. Be careful with white, use small step changes.
Posted on Apr 25, 2014
3 Suggested Answers
  • 135 Answers
SOURCE: color problem
what?
What's wrong with it?
Posted on Oct 02, 2008
virtual_a
  • 531 Answers
SOURCE: how to set brightness,contrast and
Hi
If you look carefully you should find the settings controls for the monitor are near the power button. There is a Menu button to enter the settings control panel and then direction keys to scroll and navigate through the options for each setting and then an Enter or the Menu key to activate changes. Menu or navigigating to Exit followed by Enter or Menu to close the Control Panel.
Experimenting a short while with the buttons will soon help you familiarize yourself with them.
Hope this helps
Posted on Aug 24, 2011
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I see a gray screen only when I turn thePC on. I connected my monitor to my acer extensa laptop and still stayed gray.
The CRT monitors use RGB signals for displaying colours, most of the monitors dos'nt have colour setting option, This situation can only arise whenever the RGB signals are equally of the same strength, this is an indication that the chroma section responsible for colour distribution of your monitor is now working properly, you need to examine the RGB circuitry of your monitor, one more possibility is the data cable (VGA) has been tampered internally.
Oct 05, 2009 | Acer Computers & Internet
Colour mix not right on dvd playback mainly yellow/green on screen red missing
It maybe outputing RGB to a none RGB set. Try looking in the instaltion menu for RGB Output/Input on either dvd or set.
Sep 13, 2009 | Electronics - Others
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Yellowish screen from boot up.
Once you press the menu button which is on the monitor if you get menu button then try giving reset or restore factory settings in it.
This solves your problem if your RGB colour settings is not configured correctly.
If your problem still persists then there will be problem in the monitor .
As you have mentioned (YOU HAD IT FOR A WHILE) in your problem if you have manufacture warranty then make use of it.
There is no problem with your CPU,motherboard and any other hardware part except the monitor.
Regards
-Dileep Bradley
Rate my solution
Mar 18, 2009 | LG Flatron F700B 17" CRT Monitor
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Someone made my video dvd combo black and white
It sounds like the video out put has been set to S video,go into the hv-dx300a menu and look for the video or picture out put settings and set to VIDEO or RGB, rgb is the best if it works for you.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Sony DAV-SA30 System
The color balance on my LCD monitor is hosed. How do I restore the white balance using rgb?
hi slk,
im not sure of the exact values for your rgb that would restore you white balance but you can install Adobe Gamma. Hope it helps.
Jun 21, 2008 | NEC Computers & Internet
Sony pfm42x1 colour problem
Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
Apr 22, 2008 | Sony PFM-42X1 Plasma TV
Ps2 screen display problem
Try reset to the Default Configuration, Remove the Memory Card and try this:
Press the Power and turn off,
Press the Power and Turn on, without a MC the default has been charge.
- No have a "reset sequence" but I can send to you a sequence to reset rgb without video".
Sequence: when the ps2 sound "ready" press:Down, X, Down, Down, Down, X, Right, X.
After Default Load, in "Browser" put your memory card and delete a System Configuation for the MC, the icon is a PS2, and save a new configuration, Done, if the problem not solve, send me a mail or msn gamba.support@hotmail.com (Mail and MSN)
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
LG Flatron F700B 17" CRT Monitor Logo
78 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
