Question about Cateye CC-GL10 GPS Stealth 10 Cycling Computer
Unable to downoad
My cyclocomputer is full. When I try to download, the download stops halfway thru. Saving the trips is not important to me. Is there a way to delete the trips without downloading?
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Dazzle DVD recorder software does not save my video properly
You don't say where you are trying to save it to. Try saving it to the default location on you desktop hard drive and then transfer it to your phone.
Sep 15, 2012 | Pinnacle Dazzle DVD Recorder
Just stopped working halfway thru our trip. all the fuses are fine.
Since you didn't give us any indications to accurately diagnose the problem, the only thing I can do is give you a link to the service tip manual and let you try to diagnose it yourself.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 10, 2011 | Dometic RM2652 Refrigerator
YES ITS TRUE!!!! My copy of Fable 2 only started freezing when I accidently shut off the console while it was saving. I haven't even downloaded the expansion. Now everytime I go to load my save it freezes...
Because you shut down the console halfway during saving, your save game might be corrupted. Now, I don't remember much about Fable 2 but I think that it - unfortunately for you - only uses one save game which is probably corrupted now...
Mar 17, 2009 | Microsoft Fable 2 for Xbox 360
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Machine tripped all sockets halfway through cycle
Hi.
You are going to have find the problem by elimination.
Start by unplugging the motor. and trying it again,if it still does it then you need to disconnect heater and so on, until it stops tripping
Nov 24, 2008 | Washing Machines
Computer wont download flash player
Goto ADOBE.com from there download downoad flash media player. This will install it on your pc
Jul 27, 2008 | Compaq Presario Notebook
Cateye CC-GL10 GPS Stealth 10 Cycling Computer Logo
Top Cateye Cycling Experts
John Egan
John Egan
Are you a Cateye Cycling Expert? Answer questions, earn points and help others
