Question about Logitech Formula Vibration Feedback (9633390914) Wheel And Pedals Set
Cnt tell if myag13 batteries are dead, and I was told to put four in an egg shape tube and I dont know which direction the button goes in
I purchased an egg shape ******** that requires four AG 13 batteries should the nipple side go up or down towards the spring? How can I tell if they ae dead batteries I cant get it to work
2 Suggested Answers
mikeTY
  • 8 Answers
SOURCE: put back togather
http://img107.mytextgraphics.com/photolava/2007/11/23/mx5184-48lorgeqx.jpg
check out this link for the spring location
hope this helps :)
Posted on Jun 13, 2009
Where is flasher relay on 2007 jeep patriot
Nice guess, but buzzzzzzzzzz , back to go. do not collect 200 bucks.
sadly no symptoms only my wasted time on an easter egg hunt.
hazards fail on all 4 corners, or just dash lamps fail.>????
what? the cluster has a brain too, an can fail even if tail lights flash.
the Blink DRIVER IS INSIDE THE TIPM. (under hood)
did you scan it first?
if not you many be on a wild goose chase.
MK jeep , it's in the FSM book. read it or log in to alldata.com?
there is no such thing on 07 (no relay)
(how it really works is...) bar stool, yak.
the steering stalk is now a computer
you throw the switch, the switch closes and the brain
sends a serial data command on to the buss, called LIN buss
this goes to the hood brain, the TIPM, box.
this brain hears the command and executes it. by turning on
high power transistors drivers to flash 4 lamps. (and hazard does 4)
does hazards fail too, again, no inputs from you.
there is no fuse, nor any relay. no direct fuses like old days
but are fuses , 8,17,33 but this kills many other things.
its all 100% electronic, now. "magic" i fix this stuff for 50 years.
the TIPM has 4 outputs.
so you never told me both sides fail front and rear.
so cant help much,,,,
which of 4 lamps are dead, did you replace lamps that are dead first.
that be first if one fails. not attacking the TIPM
all 4 dead, , comm errors? scan it.
one side dead. be hard for that to happen. due to 4 drivers.b
but i dont have schematic of TIPM no body does, if i had it
id was 10x smarter even saying how to fix a TIPM.
I can. (but i know now to rev. engineer parts)
tell more get more
1: are all 4 corners dead?
2: just cluster , repeater lamps dead?
3: just hazards dead?
Mar 07, 2015 | Jeep Patriot Cars & Trucks
How to tell when eggs are spoiled
Eggs are usually good for three to four weeks after the expiration date. To test, put them in water. Good eggs will drop to the bottom, rotton eggs will float to the top.
Jul 04, 2014 | Home
Our LG LFX25950SB has been freezing all the food in the refer since we purchased it 3 years ago. Had numerous service calls. They tell us we are leaving the door open, we do not have the correct...
Contact LG @ 1 800-243-0000 and let them know what is going on.
This is a known problem and a fix is availiable.
LG may help you out.
Call M-F for the american call center to answer.
If they wont you can fix it real easy.
Pull out bottom crisper dware.
Look on the back wall.
You will see a dime sized hole.
This hole allows cold air from the freezer to cool the crispers.
Cover the hole with a small piece of duct tape.
This should stop the crispers from freezing.
Also on the right wall of the ref. you will see 1 or 2 egg shapped white covers.
Remove the covers carefully so you dont break it.
You will see a 1" white thermister probe.
Pull the probe out of the insulation and clip it on the egg shaped cover and reinstall the cover.
The thermister tells the computer how cold the ref. is.
Jan 12, 2010 | LG LFX25960 Titanium Bottom Freezer French...
Battery goes dead overnight on four occasions
I dont think the dealer knew what he was doing ,your altenator has 6 diodes inside it and the are a one way check valve for current,If one fails no light will come on because it is still charging,But will drain your battery,I hope this helps you and have a merry x mas and please dont forget to vote on this solution
Dec 19, 2009 | 2009 Hyundai Genesis
Remote central locking not working on Honda CRV 1999. central locking works with Key and the alarm and imobliser work form the remote.
Hi I wonder if you can advise me ,my central locking and alarm is very unreliable it keeps making a beep before the ignition goes on and clicking,it sometimes sets the alarm off,Ive had the AA round and theyve told me the car battery is dead,which I appreciate,but think the key hub central locking or alarm is running the battery low does the hand held button need a new battery,or can I take the fuse out for the central locking,dont want to pay 66 quid for a new battery if I can pay 2 quid for a new battery for the central locking button,or demobilize it
Aug 18, 2009 | 1999 Honda CR-V
Battery goes dead intermittently
Quite often the alarm system ends up being the culprit. If you have, or know someone, who has a clamp on amp gauge that can test the draw from that circuit, it should tell you what you need to know. It could be that or a combination of various draws from your system.
Mar 22, 2009 | 2004 Cadillac CTS
KEEPS BLOWING FUESES
You have a dead short somewhere,Just start tracing wires for the ignition first.
Start with the switch and work your way back.
Feb 12, 2009 | 1999 Honda V-Twin Magna
D70 put full charged battery in, within a few seconds goes dead
Nancy,
How old is this battery? They do indeed wear out. The best way to tell is to put ii in the charger. If it charges up way too quickly, then the battery is shot.
Dec 24, 2008 | Nikon D70s Digital Camera
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Logitech Formula Vibration Feedback (9633390914) Wheel And Pedals Set Logo
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
