Question about Royal 15MX Shredder
Shredder will not operate in forward mode.
Shredder operate in reverse only, will not go forward.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
Sounds like the bin might be over full. Switch machine off. Remove top section, or open door, Empty bin. Look at shredder blades to make sure nothing is stuck in them. When sure blades are clear put back together and then switch on.
Posted on Jun 18, 2014
M2Tech1
  • 313 Answers
SOURCE: There is paper stuck in the shredder how do I get
IF YOU GET A PIECE OF THICK PAPER OR AN ENVELOPE AND FEDD THAT THROUGH IT SHOULD CLEAR IT FOR YOU YOU COULD OPEN THE DOOR AND FEED THE PAPER UP FROM THE BOTTOM BY CHEATING THE DOOOR SWITCH BY PUTTING A PIECE OF PAPER IN THE SLOT FOR THE ACTUATOR THAT WILL LET THE MOTOR RUN FOR YOU...hOPE THIS HELPS a
Posted on Jul 30, 2009
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
fellowesrep
  • 102 Answers
SOURCE: Only runs in reverse
please post brand and model
Posted on Feb 23, 2008
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
  • 1218 Answers
SOURCE: I have paper jamed in
You may have to take it apart to clear it by hand...remove the bin, remove th screws from underneath inside the cabinet and take the cutting head off the cabinet. Turn it over and remove the screws, turn it bak over and take the top off to see the insides.
Posted on Oct 07, 2010
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
A hair pin was put through our shredder by mistake and it became jammed. We cleared out the shredder and removed the hairpin however now the shredder does not operate. It will operate in reverse if you...
Yes small shredders don't like to shred metal.
You have probably blown the pcb inside the machine...would need to know make and model to provide further access for parts.
Aug 11, 2010 | Office Equipment & Supplies
For an Embassy shredder, the forward function is not working.
I was able to figure out the solution for this by taking apart the shredder.
My model is a TX61B. There is a piece of plastic that is attached to an internal sensor. You can see it below the shredder slot with a flashlight. if it is sticking out, the sensor is not tripped, and the forward function stops.
To reactivate this, just put something down the slot like a thin screwdriver to push the plastic lever back, reactivating the forward function.
I could see this being caused by running too much paper in reverse mode, which I recently did.
Aug 12, 2009 | Office Equipment & Supplies
Aurora ASa015CD shredder
any wierd noise when it goes in reverese?
is forward dead or intermittant?
most likely if reverse is perfect but forward is dead,, your control board has blown mosfets , power drivers for forward operation
Heres a few sites that have gears n boards another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
n.
new control board needed or buy a new unit depending on cost of board.
Jun 21, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Royal 15MX Shredder Logo
361 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
