Question about Kenmore Sewing Machines
Needle hitting pressor foot
Needle hits pressure foot when attempting to sew and breaks needle
    Novelist:
  • 268 Answers
Presser foot not correctly mounted, or needle bent, or needle bar loose or bent are the most likely.
Posted on May 22, 2014
SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
SOURCE: needle keeps hitting the pressure foot and breaking
your machine probably needs to be retimed.
Posted on Feb 20, 2009
  • 13 Answers
SOURCE: My janome my style 28 problem is that the needle
try changing needles
Posted on May 14, 2010
SOURCE: needle is hitting the foot
your needle is bent renew the needle
Posted on Jun 06, 2010
SOURCE: brother ls 1217 - needle continuously hitting foot and plate and breaking
it sounds like the machine is out of time, & needs to be serviced
Posted on Feb 24, 2012
Needle hitting pressure foot
Needle may be wrong size, may not be far enough up the shaft, or it is bent.
Dec 27, 2014 | Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
My quantum cxl singer sewing machine will not sew athe alphabat letters without hitting the pressure foot
it sounds like the timing is off, having the machine checked
would be a good idea, to let you know for sure.
Jul 30, 2012 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle keeps hitting the pressure foot and breaking
Feb 20, 2009 | Baby Lock Evolve
Sewing Machines Logo
146 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
