Question about U-Line Icemaker
Same problem, not woeking no noise, nothing
Turned switch on and off and the breaker at the panel, does the ice maker have its own seperate breaker ?
  • 286 Answers
No seperate breaker. You do need to look at the ejector blade. That needs to be a 12 oclock. Straight up before the hold switch can release and then the compressor and fan should come on. If you need to advance it. Remove the cover of icemaker. (pry on corners and pull cover off at same time) The smaller gear should have 5/16 head on it. Turn that counter clockwise until the ejector blade is at 12. (the fingers that pushes the ice out)
Posted on Jun 19, 2009
Sub Zero 690 ice make not working after tripping breaker
Is the "ice" icon displayed on the screen? you have to turn on ice production on a Sub-Zero
Aug 30, 2016 | Sub-Zero 690 Side by Side Refrigerator
I have a uline ice maker on my sea ray model is ulnbi95btp-03 the ice maker will not turn on I have power to the thermostat but when I remove the two wires connection the thermostat and cross them...
First take your meter and check to see if you have power going to your rocker switch if so then check to see if you have power going through the rocker switch or you can ohm the switch with out power applied to make sure switch is good, if switch is good then check the control switch power should be going to switch from rocker switch make sure power is going through control switch if so at this point you should have power to control board if so then replace control board.
Oct 29, 2013 | U-Line Icemaker
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Hoshizaki klm-450mah ice maker: nothing happens when machine is turned on. this unit has been trouble free for the last 5 years. after turning the unit on everything started as it should and one load of...
http://www.hoshizakiamerica.com/manuals/KML_F-and-H_series_serv.pdf
This is the service manual for you machine. The wiring diagrams on pages 56 and 57 shows that the machine does nothing unless the bin control is in the "Closed position. It is a temperature controled switch. If it is broken, not works. Check that out first.
Jan 13, 2011 | Hoshizaki Ice Maker 30in 550lb Crescent...
Hi, our GE icemaker is making a noise. it
You can try turning off the ice maker switch , then back on , but the ice maker is electronic . If any internal damage is done , replacing the ice maker , will be the best solution .
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
ICE MAKER AND WATER SUPPLY DOES NOT WORK
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Feb 18, 2008 | Refrigerators
GE Dryer DBL333EAOWW
Did the Dryer work before? What led to this problem? Most Electric dryers work on 240 Volts. And have their own seperate circuit breaker, usually marked as "Dryer." So resetting just the main cuircuit breaker might not be enough. Did you reset the Dryer C. breaker?
Sep 22, 2007 | Dryers
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
