Computers & Internet Logo
Receiving error code 1622 when trying to install quicken 2014
Cannot install update
2 Related Answers
Anonymous
  • 443 Answers
  • Posted on Aug 16, 2012
SOURCE: I'm trying to install Gmail Talk and keep getting Error 1622
You may follow the steps given below and check if that helps to get rid of the error message while installation of application.
a) Click on Start
b) In the start Search box type Services
c) Right Click on"services" on top of the pop up and select Run as Administrator
d) Stop "Windows Installer" service.
e) Then, delete the temp folders; there may be a file in there interfering with the setup routine of the installer. Get both:
C:\Windows\temp
C:\Documents and Settings\<username>\local settings\temp
f) Finally, set your "Windows Installer" service's startup type to "Manual".
g) Reboot your system and have another test.
Hope this information is helpful.
Thomas Smouse
  • 81 Answers
  • Posted on Apr 07, 2014
SOURCE: How do I move a copy of Quicken from my desktop to my laptop.
Hi.
When you downloaded quicken, it should by default save to a sub folder named "Download" Depending on your PC's operating system, the download folder is normally found in the "My Documents folder" Click on the Start buttom (Windows) in the bottom left corner of the taskbar. Inside the Download folder should be a file with the name Quicken.exe. Copy the Quicken.exe file to a memory stick or flash drive, then stick in into the usb port of the other PC. Click on the Quicken.exe file and it will run the installation of Quicken on the second PC. Install Quicken the same way on the 3rd PC.
Good luck!!
Methods to Fix Quicken Error OL-89-B
Quicken Error OL-89 mostly occurs when there is a temporary server outage. The first thing you can try is to update your accounts sometimes later or next business day.
Causes for Quicken Error OL-89-B
1. Account closed with a bank but still available in Quicken
2. Account information is incorrect
3. Data has some integrity issue
Kindly check out these methods in the post and see if any of them working.
https://www.quickensupportline.com/quicken-error-ol-89-b/
tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
2answers
How do I get rid of Quicken error cc-501?
Follow the steps given below:
1.Press Windows + R and then type "appwiz. ...
2.Find Quicken entry and right-click on it.
3.Choose Uninstall and make sure that all the temporary files are removed.
4.After that, download and install Quicken.
5.Now, enter your account details and check whether Quicken Error CC-501 is resolved.
https://www.youtube.com/watch?v=ZAvyVeed3m4
Where is the geely ck speedometer located?
Quicken is the most efficient financial management software that can be used by small and mid-sized businesses. Almost users use Quicken software to manage their financial data on a regular basis. This financial software permits the users to manage their necessary bank associated data through online server. But from a few days, I am experiencing Quicken error 501, while updating my Quicken account. It has created me a critical situation, so I am extremely frustrated by observing it on a regular basis. So please advise me the easy fixes for solving this error code as soon as possible.
https://www.quickensupporthelpnumber.com/blog/fix-quicken-error-cc-501/
2answers
Quicken one step update crashes
Before troubleshooting with this tutorial , make sure your version of Quicken 2014 is up-to-date. if you have some technical knowledge then chose your appropriate answer here http://support.intuit.ca/quicken/en-ca/iq/Product-Updates/One-Step-Update-Crashes-Quicken-2014/SLN77359.html and if need any technical help follow Intuit Help .
Hi.
Good luck!!
Program has to shut down as soon as I sign in
You will need to uninstall and re-install the program. Open Control Panel, Programs and Features. Find Quicken on the list and uninstall it. Reboot the PC and re-install Quicken. This should solve the problem. If not then there is another program on the system that is causing the problem and will require further investigation.
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Grand Canyon Tech
Grand Canyon Tech
