Question about Lightning Audio S4.300 Strike Car Audio Amplifier
Plugs wer can i get power plug from im in new zealand
My Power supply burned cause my brother Plugged it in the New zealand power,....Im from the STATES,...What makes me concerned is that im afraid that my console is Damaged,...Please tell me its not...
Welcome to Fixya
Looks like you have a burnt power supply. Burnt power supply wont damage the console. Purchase a new power supply and problem will be solved.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sep 29, 2011 | Microsoft Xbox 360 Console
Dont know wer to plug in the power switch which comes from the case. wil be a great help if someone can temme wer to plug the power switch.. thanks
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light and a magnifying glass to see the marks and they are usually at the bottom right of the motherboard.
Regards.
Apr 28, 2011 | MSI K7N2 Delta-ILSR (MS-6570-030)...
What petrol grade should I be using in my zzr 400 Im in New Zealand, I have just filled up on shell v power and it is missing and stuttering real bad.
I don't know what you have in New Zealand, but you probabley will want to use the premium (best grade) fuel. You can fix the current tank full by adding an octane booster available from a local auto parts store.
You could do some math and figure out if it's worth useing octane booster with cheaper fuel..
Nov 28, 2010 | 1991 kawasaki ZZR 400
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: https://www.manualslib.com/manual/201694/Samsung-Syncmaster-2333sw.html?page=11#manual Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hi iv got a4 2.8 with a blown frost plug do i need to take motor out to fix it im in new zealand
if you can get to it with a hammer and tap it in evenly,all round, then no.....(i use a socket inside the cup,then hit it.)
May 19, 2010 | 1997 Audi A4
My brother has the same 1521 laptop as mine. My power supply works fine on his and my battery. When your plug it in to my laptop it kicks the green power light off on the power supply. I get no lights no...
Hello
Thank you for using FixYa for your problem
It sounds like the DC jack maybe faulty ( where you plug the power supply (ps) into)
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Dell Inspiron 1521 Laptop
97 chevrolet cavalier z-24 2.4 ets code and chech engine flashing
  1. Im assuming you have a quad 4 engine.. so remove the cover w 4 bolts and inspect the plastic where the 4 plug boots go for cracks , this was a common problem with these engines, if none are found replace the ignition coil thats defective ..Not likely to be a coil..but you never know I'm more inclined to say hairline cracks in the coil retainer .. ps if the catalytic converter got as hot as you say,, its likely toasted and will fail an emissions test like we have in ontario canada ..good luck,,eh lol
Nov 30, 2009 | 1996 Chevrolet Cavalier
It is leaking from the block but under a host wer i can not see.
you may have to take the motor mounts loose and jack it up to get to it
Nov 21, 2009 | 1994 Honda Accord
Help with speakers!@!@!@@!!
The odd plug coming out of the speakers is to connect to a power adapter to power the speakers, the other is to plug into the output plug of your sound card. Normally this is color-coded on the back of the computer in a light green colour.
Dec 05, 2008 | Dell AS500 Sound Bar Computer Speakers
Lightning Audio S4.300 Strike Car Audio Amplifier Logo
Top Lightning Audio Car Audio & Video Experts
80stech
Richard Lukszys
Richard Lukszys
jason
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
