Question about Ricoh Aficio 2022 All-In-One Laser Printer
Says that I need to replace toner but there is plenty of toner in the cartridge.
The green handle of the toner broke off. Do i need to replace only the handle?
  • 3 Answers
Just the handle. You can test it by pushing in and twisting the know that has 2 ends sticking out. This should load the toner without the handle being necessary. Ryanluke.net
Posted on Mar 19, 2014
    Problem Solver:
  • 9 Answers
Replace the whole toner holder assembly as the auger inside of it goes bad which causes the user to keep pulling out the toner bottle and checking it which in turn brakes the green handle
Posted on Mar 18, 2014
Xerox 3550 toner install
Replace the print cartridge using the following instructions:
1. Release both latches on the side of the front door and open the door.
2. Pull the print cartridge out.
3. Remove the new print cartridge from its bag.
4. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge. It will provide maximum copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
CAUTION: Do not touch the green underside of the print cartridge. Use the handle on the cartridge to avoid touching this area.
5. Hold the print cartridge by the handle and slowly insert the cartridge into the opening in the machine.
6. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
7. Close the front door. Make sure that the cover is securely closed.
Nov 22, 2012 | Xerox 3550 AllInOne Laser Printer
I ran out of toner so I ordered a new black toner cartridge. It arrived today. I can not find the directions to replace it in the literature I have for the MC 2400 W. How do you replace the toner...
push rotate button until it get to black, pull the handle on the front of the toner and release/remove the old one. Line pegs up with slots and lock in place. close all compartment doors.
Apr 26, 2011 | Konica Minolta magicolor 2400 Laser...
I cannot get the toner cartridge out of the machine!!!!
Here are the steps to change the toner cartridge.
1. Open the front cover (there is a handle just above the manual feed and just below the screen and buttons).
2. Inside there will be a handle facing you; this is the cartridge assembly (toner cartridge + drum unit). Pull the handle straight out. There are no buttons or switches to press, simply pull the handle and the assembly will slide out.
3. On the side of the assembly there will be a small green tab. Press it to release the toner cartridge.
4. Pull the toner up and out to separate the drum unit. (DO NOT touch the imaging roller on the drum! It is a green or blue tube in the front of the drum unit).
5. Put your new cartridge into the drum unit.
6. Slide the cartridge assembly back into the printer until it clicks into place.
7. Close the front cover.*
*If the front cover doesn't close easily, the cartridge assembly is not installed correctly. If this occurs, take the assembly out and reinsert it.
I hope this helps! Good luck!
Feb 28, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a HL4040CDN it said the Cyan was out and we replaced it with a new one and it says the same thing. Checked and found no problem.
SIR/MADAM
If you have print quality problems, clean the drum unit as follows:
1.Turn off the printer power switch. Press the front cover release button and then open the front cover.
2.Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
3.Release the gray lock lever (1) that is on the left side of the printer. Pull the drum unit completely out of the printer using the green handles on the drum unit.
  • We recommend that you place the drum unit on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
  • Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
  • Hold the handles of the drum unit when you carry it. DO NOT hold the sides of the drum unit.
4.Hold the handle of the toner cartridge and pull it out of the drum unit. Repeat this for all the toner cartridges.
5.Turn the drum unit over by holding the handle. Make sure that the four drum unit gears are on the left side and the drum unit gear "1" is located furthest away from you. The numbers can be found on the drum unit gear.
6.See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Put the print sample in front of the drum, and find the exact position of the poor print.
7.Turn the drum unit gear toward you by hand while looking at the surface of the drum (1).
8.When you have found the mark on the drum that matches the print sample, hold the middle of a cotton swab and wipe the surface of the drum gently until the dust or paper powder on the surface comes off.
Caution DO NOT clean the surface of the photosensitive drum with a sharp object.
9.Turn the drum unit gear toward you by hand to return it to the home position. The home position of each drum can be identified by matching the number on the drum unit gear to the same number on the left side of the drum unit.
10.Make sure that the number on each of the four drum unit gears matches the corresponding number on the side of the drum unit.
11.Using the green handles turn the drum unit back over.
12.Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum unit, and make sure that you fold down the toner cartridge handle (1) once the toner cartridge is in place. Repeat this for all the toner cartridges.
13.Put the drum unit back in the printer as follows.
  1. Make sure that the gray lock lever (1) is in the up position and put the drum unit in the printer. Push down the gray lock lever (1).
When you put the drum unit in the printer, match the green guides (1) of the drum unit handle to the green arrows (2) on both sides of the machine.
2.Push the drum unit in until it stops.
14.Close the front cover.
If your question was not answered, Please Visit Below URL For Brother Printer Issue:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002200/000056/faq002256_001.html?reg=us&c=us&lang=en&prod=hl4040cn_all
OR
In Case You Still Need Online Assistance For Online On:
Brother Printer Support
1.
7.
9.
10.
13. 18702e13-4079-4a6c-b6e8-bf7ca3a1724e.gif 39941d87-a31f-42a9-8cc5-c22f21528c55.gif
Jan 28, 2011 | Brother HL4040CDN Duplex Unit
There is a massage in red that reads drum error
Brotherstrongly recommends that customers do not use generic drum units and/or tonercartridges, or refill their Brother toner cartridge. Each Brother laser printeris designed to work at pre-set temperatures that are matched exactly to each ofour individual toner formulations. Each individual component is designedto work with the other to ensure quality and reliability. Using non-Brothersupplies may affect the hardware performance, print quality, and machinereliability. The Brother limited warranty does not apply to any problem that iscaused by the use of unauthorized third party drum units, toner cartridges, ortoner. Turn off the printer power switch. Press thefront cover release button and then open the front cover. Hold the green handle ofthe drum unit. Lift the drum unit up and then pull it out until it stops. Hold the handle of thetoner cartridge and pull it out of the drum unit. Repeat this for all the tonercartridges.
    • I recommend that you place the toner cartridge on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
    • DO NOT put a toner cartridge into a fire. It could explode, resulting in injuries.
    • To avoid print quality problems, DO NOT touch the shaded parts shown in the illustrations.
Push to release thelatches of the white corona wire cover (1), and then open the cover. Clean the corona wireinside the drum unit by gently sliding the green tab from left to right andright to left several times. Be sure to return thetab to the home position (1). If you do not, printed pages may have avertical stripe. Close the corona wirecover. Repeat steps 4-6 to clean each ofthe remaining corona wires. Hold the handle of the toner cartridge and slide the toner cartridgeinto the drum unit. Make sure that you match the toner cartridge color to thesame color label on the drum unit, and make sure that you fold down the tonercartridge handle (1) once the toner cartridge is in place. Repeat this for allthe toner cartridges. Put the drum unit backin the printer. Close the front cover ofthe printer.
Nov 16, 2010 | Brother HL-4040CN Laser Printer
Inatallation of a printer
Hello , I believe I can help you out.
First here is a bit about your machines toner maintenance.
Second will be how to change the cartridge.
Remember if I was of assistance please be kind and leave a kind quick testimonial and good rating.
Maintaining the toner cartridge
Toner cartridge storage
Toner cartridges contain components that are sensitive to
light, temperature, and humidity. Samsung suggests users
follow the recommendations to ensure the optimum
performance, highest quality, and longest life from your
new Samsung toner cartridge.
Store this cartridge in the same environment as the printer
it will be used in; this should be in controlled office
temperature and humidity conditions. The toner cartridge
should remain in its original, unopened package until
installation – If original packaging is not available, cover
the top opening of the cartridge with paper and store in a
dark cabinet.
Opening the cartridge package prior to use dramatically
shortens its useful shelf and operating life. Do not store on
the floor. If the toner cartridge is removed from the printer,
always store the cartridge:
• Inside the protective bag from the original package
• Correct side up in a horizontal position (not standing on
end)
• Do not store consumables in;
- Temperature greater than 40°C (104°F).
- Humidity range less than 20% and not greater than
80%.
- An environment with extreme changes in humidity or
temperature.
- Direct sunlight or room light.
- Dusty places.
- A car for a long period of time.
- An environment where corrosive gases are present.
• An environment with salty air.
Handling instructions
• Do not touch the surface of the photosensitive drum in
the cartridge.
• Do not expose the cartridge to unnecessary vibrations
or shock.
• Never manually rotate the drum, especially in the
reverse direction; this can cause internal damage and
toner spillage.
Use of non-Samsung and refilled toner
cartridge
Samsung Electronics does not recommend or approve the
use of non-Samsung brand toner cartridges in your printer
including generic, store brand, refilled, or remanufactured
toner cartridges.
CAUTION: Samsung’s printer warranty does not cover damage to
the machine caused by the use of a refilled, remanufactured, or
non-Samsung brand toner cartridge.
Estimated cartridge life
Estimated cartridge life (the life of the toner cartridge yield)
depends on the amount of toner that print jobs require. The
actual print-out number may vary depending on the print
density of the pages you print on, operating environment,
printing interval, media type, and/or media size. For
example, if you print a lot of graphics, the consumption of
the toner is high and you may need to change the cartridge
more often.
Redistributing the toner cartridge
When the toner cartridge is near the end of its life:
• White streaks or light printing occurs.
• The warning message, Toner Low displays on the control
panel.
• The Smart Panel program window appears on the computer
telling you that the toner cartridge is low on toner.
• The Status LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the toner cartridge. In
some cases, white streaks or light printing will still occur even
after you have redistributed the toner.
1 Open the front cover.
2 Pull the toner cartridge out.
3 Thoroughly roll the toner cartridge 5 or 6 times to
distribute the toner evenly inside the toner cartridge.
NOTE: If toner gets on your clothing, wipe it off with a dry
fabric
Changing cartridge:
_______________________________________________________
CAUTION: Do not touch the green underside of the toner
cartridge. Use the handle on the toner cartridge to avoid
touching this area.
4 Hold the toner cartridge by the handle and slowly insert
the toner cartridge into the opening in the machine.
5 Tabs on the sides of the toner cartridge and corresponding
grooves within the machine will guide the toner cartridge
6 Close the front cover. Make sure that the cover is securely
closed.
Replacing the toner cartridge
When the toner cartridge is completely empty:
• The printer stops printing.
telling you that the toner cartridge is empty.
• The Status LED lights red.
At this stage, the toner cartridge needs to be replaced. For
order information for toner cartridges, see page 7.1.
1 Pull the toner cartridge out.
2 Remove the new toner cartridge from its bag.
3 Roll the toner cartridge 5 or 6 items to distribute the toner
Thoroughly rolling the toner cartridge will assure
maximum copies per toner cartridge.
4 Remove the paper protecting the toner cartridge.
fabric.
touching this area.
5 Hold the toner cartridge by the handle and slowly insert
6 Tabs on the sides of the toner cartridge and corresponding
7 Close the front cover. Make sure that the cover is securely
closed.
Good Luck!
Mar 30, 2010 | Samsung SCX-4300 Monochrome Laser...
How do I install the toner cartridge?
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green handle up to its full extent
  4. Press and hold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release the green lever
  6. Pull out the Toner Tray to its full extent
  7. Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  8. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  9. Dispose of the Toner Bottle in accordance with your local environmental instructions
  10. Obtain a new Toner Bottle and shake it gently from side to side at least 5 times
  11. Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  12. Push the neck back into the black housing of the tray
  13. Push the whole assembly back into the device until it clicks into place
  14. Push the green handle down fully and close the Front Cover
  15. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Aug 17, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Cartridge not installed message
This worked for me
Each toner cartridge has a small green chip with 3 gold-colored contacts on it. First thing to try is to rub those contacts with an ordinary pencil eraser. You will need to rotate the toner carousel to get to all 4 sets of them. To get it to rotate, there is a little square-ish hole in the white plastic housing to the right of the toner cartridge that is visible when the top cover is raised. Push a pen down in the hole, which will push on a tab allowing you to rotate the toner carousel until you can see the next cartridge. Repeat for all four toner cartridges. Close up the printer, power it up, and see if it solves the problem. If not, do this: Remove the drum (gently pull on the green handle). Be careful not to touch the roller or let it contact anything. Get a flashlight, look down inside the printer on the right (it's kind of hard to see, it's almost under the toner cartridge). You will see a black sensor switch with three wire-like contacts, surrounded by a square white housing. Wipe off those contacts, if you can get the eraser in there better yet. Contacts are kind of flimsy, be VERY careful you do not bend them. Next, take the point of a pencil and push on each contact, it should move in and return when released. If that seems good, put it all back together and try the printer again.
Mar 28, 2008 | Minolta 2430DL Color Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
