Question about Toro Garden
Wont start been idle 4 months 9 months old unleaded in tank 4 months
Model 74560
  • Toro Master
  • 2,478 Answers
If you didn't kept gas in carb. and didn't add stab-loc. You need clean the carb.
Posted on Mar 19, 2014
2 Suggested Answers
Tech_Mate
  • 680 Answers
SOURCE: I inadvertantly placed the fuel
It won't do any harm in fact it may do it some good. The only real side effect I can see is a little smoke comming out of the exhaust.
Terry
Posted on Feb 12, 2011
Testimonial: "Feedback was timely and assisted with the problem. A great site to visit but unfortunately not well known as I stumbled on it accidently "
My 01 katana been sitting up it will crank idle for a few than die out and wont crank until it sit awhile
Hi, Kevin and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike dies when you give it throttle
Suzuki GSX600F Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Oct 04, 2016 | Suzuki GSX 600 F (Katana Motorcycles
Low idle when warm and wont start back up
Hi, Anonymous and the usual suspects are:
Wont start when hot bogs out alot in first wont idle normal Yamaha R1...
http://www.r6-forum.com/forums/58-exhaust-fuel-delivery/177793-06-r6-wont-idle-after-restart-when-engine-hot-help.html
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 24, 2014 | 2001 Yamaha YZF-R6
Won't start without choke
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Motorcycle Message Board Motorcycle USA
http://www.r6messagenet.com/forums/r6-maintenance-technical/117461-wont-start-without-throttle.html
Jan 08, 2014 | 1999 Yamaha YZF-R6
2008 harley dyna street bob wont idle after it warms up
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Nov 11, 2013 | Harley Davidson Motorcycles
110cc suzki wont stay idling
Hi, Mark and the usual suspects are:
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
DRZ 110 wont stay running
How to fix dirt bike that wont idle
Kawasaki KLX110 Service Manual
Jun 12, 2017 | Suzuki Motorcycles
Yamaha pw 80 wont idle
Yamaha pw80 wont stay running
1989 Yamaha pw80 won idle
YAMAHA PW80 Owner Service Manual
YAMAHA PW80 Owner Manual
Oct 21, 2012 | Yamaha PW 80 Motorcycles
I inadvertantly placed the fuel and oil mixture into the fuel tank of a 4 stroke petrol mower when it should have been unleaded fuel only. How do I rectify this problem. The mower is a Rover i4500 model...
Terry
Feb 12, 2011 | Garden
I have a 98 TJ 2.5, does anyone know if it has another numbers in the chassi? (except the three plates inside the car) tnanks
hi no there is only the ones on the inside the layout should be like this for your one
1 Country of Origin 1 = United States 2 Make J = Jeep 3 Vehicle Type 4 = MPV 4 Gross Vehicle Weight Rating E = 3001-4000 lbs.
F = 4001-5000 lbs. 5 Vehicle Line Y = Wrangler 4×4 6 Series 1 = Sport
2 = SE
4 = Sahara 7 Body Style 9 = Open body 8 Engine P = 2.5L Unleaded Gasoline
S = 4.0L Unleaded Gasoline 9 Check Digit 0 through 9, or X 10 Model Year W = 1998 11 Assembly Plant P = Toledo #2 12-17 Vehicle Build Sequence Six Digit Number
incase the picture did not come out
2 Make J = Jeep
F = 4001-5000 lbs.
6 Series 1 = Sport
2 = SE
4 = Sahara
hope this helps.
Nov 13, 2010 | 1997 Jeep Wrangler
Hi I have a 1967 bsa bantam d10 175cc. The bike still has petrol in the tank from 1974 when it was last running. I wont to flush out the tank with fresh petrol, But I am not sure if the bike can run on...
the bike can run on unleaded but it will be rough .
you mwill have loss of power and radical .
what i would suggest is to ask a mechanic about the effects of unleaded petrol to an old engin .
all i know is that the bike will run as i did it to my old BMW and all i had to do is replace some gaskets .
Best of luck .
Sep 30, 2009 | 1970 Triumph T 100 R
My saab wont start
Uh...Try Shell
Jul 21, 2009 | 1999 Saab 9-5
Garden Logo
48 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
