Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Need service manual for kenmore range 119 9246800
Need wiring diagram
2 Suggested Answers
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
Posted on Sep 14, 2009
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
How can I get a wiring diagram for part number 316436001?
The wiring diagram should be on the range that the switch is going on. That's a Frigidaire part number and they usually put the wiring diagram on back of unit. If not, you can look at the other switches and just match up and wire the same. Be careful and Good Luck
May 21, 2016 | Kenmore Kitchen Ranges
Wiring diagram for ge 3 coil range burner
Go to the back of the range. The wiring diagram with be on the back, or inside the top console. They hide them there for service engineers. Washing machine diagrams are in the bottom or in the top console, Fridges are behind the back of the freezer to the right of the evaporator coils.
Your colour coding is probably the same on all burners. There is normally only two wires.
May 16, 2016 | GE Kitchen Ranges
I have a kenmore model 790.46893900 glass cooktop 0ven and i need to no where each of the 6 wires hook up exactly? they are the wires in clock and control digital display.
There is an old saying amongst Technicians. If you don't have a wiring diagram, mark every wire where it goes before you unplug them. The oven should have a wiring diagram somewhere behind one of the covers. If it doesn't, you may need to contact Kenmore or one of their Agents to see if they have a service manual detailing the wiring connections. Sorry , but I don't have any info on Kenmores. I don't think they are sold in Australia.
Sep 15, 2015 | Kenmore Kitchen Ranges
Need wiring diagram and service manual
Hi, can you please provide details of the model, thanks
Jun 19, 2015 | Washing Machines
Wiring Diagram for a Flavel Range master cooker
I don.t have a manual,that is hard to find,yet a oven is a basic device,most of components can be id and tested by amateur electronic,like switches,fuses,heater resistance,control board.no need to remember Electric Shock Hazard !!
regards
Oct 28, 2014 | Car Audio & Video
Unhooked 4 wires on door lock mecinasm on kenmore gas range model #66575002100 can't remember which one goes where
Here is part of the wiring diagram for that
It looks like the gray wires go to the switch either one in either end of the switch and the White and Brown go to the motor.
May 08, 2010 | Kenmore Kitchen Ranges
I need a wiring diagram for a Kenmore Ultra dishwasher
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Also - if your unit has never been serviced - there is a service manual inside the shell - or behind the control panel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | Dacor Epicure ERV30 Kitchen Hood
How do I install new belt on Kenmore stackable #41789390800
look in the console - or inside the dryer shell for the service manual. All wiring diagrams are in the service manual.
Mar 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
One of the burner does not work on my electric Kenmore stove.
the eazy answer is its the burner.i only say that because on most service calls with your complaint it dose indeed end up being the burner.but before i come to that conclusion i do check the out put of that burners switch.if has 220 volt output then its the burner,even tho if you look at the wiring diagram it will show a limiter before it gets to the burner but that part is built in to the switch and is not replacable on its own.so then use volt meter take a look at your wiring diagram .look on that diagram and decide which wires are leaving the questioned switch that controls your bad burner .place your probes on those wires again if reads 220 volts replace the burner. i hope this helps .God bless ,tom
Jan 04, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
21 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
