Question about 2004 Volkswagen Jetta - Sedan - Base Rack System
After the car sits over nite it will start but after you shut it off it wont restart
It wont start
    Problem Solver:
  • 8 Answers
Check yr batt, might need replacing
Posted on Apr 26, 2016
    Habit-Forming:
    Scholar:
  • 152 Answers
Sounds like something somewhere is pulling your battery power. Check under the hood to see if you have any Belt Chaffing on any of the electrical cables that may be near any fan belts of pulley wheels. sometimes you could even find the Fan Belt embedded into the side of a cable creating a short since your fan belt has wire inside of it, it could give you momentary power once cranked but will draw out on its own leaving the battery to charge on it's own cells.
Posted on Apr 24, 2016
    Sergeant:
  • 361 Answers
Sounds like it is not charging , when you start it the battery recharges ove rnite yes sometime this will happen with a good battery , then when you start it, it is running of the batery and will not start because the draw from the battery kills it , ck your charging system
Posted on Mar 19, 2014
Truck wont start up
check that the battery posts and terminals are shiny clean and tight. Have a load test done on the battery as it indicates a bad cell.
Jan 23, 2014 | 2005 Ford F-150
Pontiac sunfire problems
check for failing coil/s and excessive current flow through them.
Dec 04, 2013 | Cars & Trucks
1996 GMC JIMMY, Hard starting after it has ran for awhile
could have a battery ground , check cables for corrosion.
could also be the starter or the solenoid.
you could also have a dead short in the battery itself, it will be ok if it sits but will give you fits for repeated starts
Apr 16, 2013 | Cars & Trucks
Quits after warm up wont restart
sounds like you have a fuel pump problem, fuel pumps will usually get hot and then shut off allowing it to sit 30 mins lets the pump cool down allowing it to start pumping, the way you can test it is get a can of starting fluid the next time it quits raise your hood and spray some fluid down into the throttle body and if it starts and then dies it is most likely your fuel pump, hope this helps.
Feb 02, 2013 | 1999 Dodge Dakota
Truck turns over good but wont crank.drift 6 inches drop clutch start right up and start all day
If the starter motor is fine, then how do you know this if it isn't energizing? Have you tested it independently?
If it isn't receiving power, then it is possibly an issue with the solenoid, or ignition.
Nov 03, 2012 | Cars & Trucks
My car shuts down while i'm drivng it. After sitting for a minute it will restart. But only after sitting for a minute.
Sounds like your ignition coil is failing. Eventually it wont start at all Common problem
Jun 15, 2012 | 1993 Mazda MX-6
2001 ford taurus car starts fine drive it for awhile then shut it off and it wont start let it sit and it will start battery is fine
Does it crank?If you shut it off and you restart after a few minutes and it cranks but won't start or starts and runs rough the injectors are leaking and flooding the engine. Need better description
Dec 07, 2011 | 2001 Ford Taurus
2001 chevy silverado 1500 headlights wont shut off
You will have to have the dealer reset the security light to restart vehicle.Check all engine and chassie grounds because this is where the lighting would exit the vehicle.It sounds like a ground burnt through.
Jul 19, 2009 | 2001 Chevrolet Silverado 1500
Won't start
disconnected the battery last nite, reconnected this morning, started right away.
I noticed a cell phone charger was plugged in, I am hoping this is the thing that was draining the battery, if not, will look further.
Jul 06, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
2004 Volkswagen Jetta - Sedan - Base Rack System Logo
60 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
L Pfaff
L Pfaff
Rocguy
ray012965
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
