Question about Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
My 6 year old Sylvania 32" Digital/Analog LCD TV w/built in DVD PLayer cuts off repeatedly. 8 out of ten times it will come back on within several seconds. The other 2 out of ten times I have to power
Unit turns itself off and back on again after several seconds. happens repeatedly. sometimes will return on, sometimes I must use the remote to power back up.
    Top Expert:
  • Sylvania Master
  • 75,386 Answers
Sounds like a loose contact at its main power regulator board. Contact any service technician. Gopakumar Gopalan Google
Posted on Mar 19, 2014
  • 163 Answers
SOURCE: Sylvania SRPD442 42 in. EDTV-Ready Plasma
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Posted on Aug 11, 2006
Randyincv
  • 17 Answers
SOURCE: i have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
Take the Inverter Board out and check for Open windings on the 6 Transformers along the edge of the board. When you find one open, get the number off of the Transformer, Google it, buy one and replace the bad transformer. I was given one of these TV's and fixed it for $11. It's not rocket science, if you can use a DMM and a soldering Iron, you can fix this.
Posted on Nov 06, 2009
  • 27 Answers
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Posted on Apr 10, 2010
maatmartin7
  • 1229 Answers
SOURCE: my tv turn off by
Hmmmmm.......My ratings are slipping so this will require a serious answer! The solution I will give you will be of most accuracy. Your power supply startup resistors are are bad. These are located on the inverter board. Replace the inverter board or if you are up to it replace R603,604, and 605 with 390K quarter watt resistors. If the values are different or the same as mentioned, use the values I just told you! If they look fine or test fine...replace them with the value just mentioned!!!!!! Anyway!!!!!! Take this info to a TV tech and show him your answer. Thanks for asking me!
Posted on Aug 08, 2010
  • 608 Answers
SOURCE: I have a Sylvania LC370SS8
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Tip
Sylvania LD200SL8 Manual Download
Download Sylvania LD200SL8 LCD TV with DVD Player Manual
Have you misplaced your Sylvania LD200SL8 LCD TV with DVD Player Owners Manual?
Would you like a digital, searchable, pdf version of the Sylvania LD200SL8 LCD TV with DVD Player Users Guide?
Follow this link (& click Free) to download a pdf version of the operations manual.
I hope that helps.
on Apr 27, 2010 | Sylvania LD-200SL8 20 in. EDTV LCD...
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
Does this product have a built in digital to analog converter?
This tv incorperates a full digital PLL tuner. It does not need a digital to analog coverter since analog signals is no longer used. All tv stations now broadcast with digital signal. It will receive local broadcast stations just connect a goood quality antenna to the tv. You will need to do a scan and the tv will store all of your local broadcasting stations within range. An outdoor antenna works best for digital signals.
Sep 13, 2012 | Samsung LN32B460 32 in. LCD HDTV
Sylvania tv not recognizing DVD player
Do one thing press the SCREEN MODE button on the remote repeatedly and check is there is any difference in the screen. If there is no difference then yu tv Have problem wit the T Con board, T con board is on which drives pixels the lcd screen. You can find the T con board of your tv in the following link.
Normally you can find the T con board inside the tv at the bottom center covered by metal cover or aluminum foil. Replacing this board will solve the problem.
http://www.ebay.com/itm/BUF320G04012-T-CON-SYLVANIA-LC320SS8-/140556173476
If you need any more assistance feel free to contact me through fixya
Ajin
Nov 23, 2011 | Sylvania LC320SS8 32 in. LCD Television
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
I have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
May 22, 2008 | Sylvania LC370SL8 37 in. LCD Television
Sylvania LD-320SS8 32 in. LCD TV/DVD Combo Logo
101 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
