Question about Sonic EV SonicXS 4.1 Computer Speakers
Bosch sonic ev 4.1
Remove back panel of subwoofer
How do i remove the top panel from a bosch wtl5410 dryer?
Go to www.repairclinic.com and enter WTL 5410. If this site covers Bosch appliances you will be presented with a list of common replacement parts and more importantly may be able to view a generic Bosch video showing disassembly.
Nov 20, 2017 | Bosch Axxis WTL 5410 Electric Dryer
How do I open up an EV sx100+speaker to fix the diaphram?
I just replaced diaphragms in the tweeters in a pair of EV Sentry 200 speakers. The tweeters had 4 bolts holding them together. One of them was stuck. It's just a matter of gently but firmly twisting it back and forth until it starts coming apart. Make sure you take it apart evenly or it will bind.
Sep 12, 2012 | ElectroVoice . Speaker
Need owner`s manual
you can download Sonic EV SonicXS 4.1 Computer Speakers manual from this link below:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000011734.pdf
Aug 06, 2010 | Sonic EV SonicXS 4.1 Computer Speakers
How much oil and what type goes back in the bosch 11241 evs
The best way is to find a Bosch service center and get the oil change kit. P/N 1615437511 this comes with a small bottle of oil and a top cover gasket. All you do is remove the top cover dump out the old oil and pour in the whole bottle of the new stuff. Couldn't be more simple.
Aug 01, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
Car amplifier
HI PAL BUY MONOBLOCK AMP TO DRIVE UR SUB TRY GET ROCKFORD FOSGATE, KICKER,BMBOSCHMANN,OR INFINITY
Jun 03, 2009 | ElectroVoice EVM10DLX Car Subwoofer
No sound on EV SonicXS 4.1
Good day Idn2000
you may check also in the manual your actual conection, and see if is the right, then check on control panel and speaker setup, for 4.1 setting. if the speakers don't work,at back, something is bad inside the controller, on sub. be carefull opening and moving things inside, but you can check that .
Nov 28, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
EV sonic XS 4.1 computer speakers and amp
Hi CarrieBeth
depending on the brand of your speakers (creativelabs) etc, have different models, but some of them have problems with AMP, and subwofers. Send me your brand or model, to help you out more direct, or depending on the brand, some models lile 5600 from CL. have problems on the AMP module on the sub. have to change or fix the AMP chip.
hope I can help
Carl
Nov 16, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
I only hear sound out of two speakers........
Have you set the computer up for 4.1 speakers in the audio software? Go to start control panel and click on sound's speech and audio device's, then click on sound's and audio device's. A window should pop up with a load of menus at the top, click on the one that says volume. Where it says speaker settings click on the advanced button. Click on the menus until the picture lookslike your system you have.
Feb 19, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
Sonic EV SonicXS 4.1 Computer Speakers Logo
42 people viewed this question
Top Sonic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Martin Murray
 Grubhead
Grubhead
Are you a Sonic Audio Player and Recorder Expert? Answer questions, earn points and help others
