Question about Refrigerators
My Fisher Pakel E440T freezer and fridge slowly warmed up and I had to manualy defrost it. The freezer fan is working and I feel it will do the same again. From previous experience with another brand of fridge I suspect it may be the defrost timer unit but I cant locate it. My model has not got a kick unit in the front, the only access to working parts is at the back of the freezer or at the back of the cabinet at the bottom. There is some sort of an electronic control box labelled P42 STG4. Any suggestions would be greatly appreciated. Scotty 19 March 2004
  • 36 Answers
SOURCE: top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Posted on Dec 16, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
SOURCE: Kenmore fridge electronic defrost manual start procedure
unplug overnight started OK
Posted on Jun 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Hi, I have a Fisher and Paykel E402B
Your automatic defrosting circuit is not working. There are several components that can stop the defrosting process:
1. The defrost control
2. The defrost element
3. The defrost thermostat
Any one of the 3 can open cause the automatic defrosting process NOT to work.
If the defrost control fails, it just stops defrosting and ice builds up on the evaporator coils.
If the defrost element fails it will go into the defrost cycle and not cool again until the internal temps reach 60 Deg F.
If the defrost thermostat fails in the open position the heater will not heat up and the freezer will ice up.
There are 6 models of the R402B so I was not able to narrow down a source your exact parts data.
However, if the defrost control has failed the good news is the most expensive one is $18.95 AUD
Hopefully this gives you something to go on. I think it will either be the defrost control or the thermostat. If you can locate the defrost control turn it until it clicks ONCE and see if the unit shuts off and completes a defrost cycle. If it heats up but does not complete the defrost cycle again your looking at a problem with the defrost thermostat. If it does not heat at all then the problem is the heating element.
The defrost control will have 2 sloped tabs on it so that you can only turn the control one direction. The defrost control dial with the tabs will be no larger than 1/2 inch in diameter.
UK Parts: http://www.partmaster.co.uk/cgi-bin/search.pl?query=Fisher+%26Paykel+E402B
AU parts: https://www.statewideapp.com.au/shop
You most likely will have to make a "contact" enquiry at either site above. For the defrost tmer, heating element or the defrost thermostat.
Thanks for choosing FixYa,
Kelly
Posted on Jun 21, 2011
Testimonial: "Thanks heaps. You guys are great."
martineznoe8
  • 92 Answers
SOURCE: hi,i have fisher pakel E522B
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Posted on Jul 04, 2011
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
I have an active smart fridge freezer. The freezer seems ok but the fridge has stopped working but it doesent get cold. how can it be fixed. It is only 18 months old.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
My freezer is fine but fridge side is warm and no air blowing
SOUNDS LIKE THE FAN FROM THE FREEZER TO THE FRIDGE TAKE OFF THE COVER TO SEE IF ITS WORKING
Sep 02, 2009 | Maytag 26 cu. ft. Wide-By-Side...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
Top of fridge warm but bottom freezer working ok
Dear customer,
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Nov 06, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
REFRIG E402BRE
My fridge (E440T but I believe the E522 is similar) has EXACTLY the same symptoms and the reason was a broken fan wire in the freezer compartment (behind the rear panel). The fridge compartment works by drawing air from the freezer and blowing it into the fridge compartment. If the fan in the freezer doesn't work, then your fridge won't get cold (there is another fan in the fridge compartment so it will stay a little cold but not enough).
If you're game, I created a document for others to follow if interested at http://mail.accentis.com.au/downloads/misc/How%20I%20fixed%20my%20Fisher%20and%20Paykel%20Fridge%20Active%20Smart%20Fridge.pdf
Thanks to all postings on this site - it really helped a lot, had me some fun and saved money!
Jun 16, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
