Question about Westinghouse VR-6025Z 60" LCD TV 1920x1080, 120 Hz, HDTV
Tv doesn't power on
Tv won't power on. It has power to it but will not turn on. No normal noise of when you do turn the TV on. No video or audio. The power board has no visible bulging capacitors. Fuse tests good on ohm meter.
  • Westinghouse Master
  • 1,527 Answers
Hi i'd check the voltages on the connector on the power board, it sounds like you have 5v standby, i'd check for 12v and 24v or look for a tv tech in your area
regards
shaun
Posted on Mar 19, 2014
  • 29 Answers
SOURCE: Westinghouse Digital Electronics LCD TV Model w32701
I had the same problem..."No video but the Sound/audio was working fine." This is my solution.
Dissamble Procedures:
1. There are 4 different types of screws used. So, you can copy my technique. I used masking tape. Everytime I took out screw I taped it beside the hole.
2. You can pull the Video/Audio RCA box by plier, it is detachable.
3. You can pull also the antenna input box by plier.
4. When taking out the Inverter board, you have to flip the lcd upside-down. There are 4 screws at the four corners.
Soldering Solutions.
I soldered all 7 transformer's legs. 8 legs each transformer. I soldered also the 8 capacitors. Checked the 4 fuses.
Main Part of Solutions.
The problem was coming from the 2 surfaced mount inductors. That's why there was no supplied power (voltages) going to the inverter.
These 2 tiny inductors are labeled as L21 and L168 connecting the 12v supply and transfering the power to the inverter. IMAGINE THESE 2 TINY PIECES CAN DISABLE YOU VIDEO? That's why even if you are going to buy a new Inverter board it will not solve the problem. Because the 2 inductors are not connected fully (cold solder) although by naked eye they seems fine. Solution resolder them both.
I used 30w Radioshack soldering Iron. Don't use the 40w because the tip is thick and can damage the neighboring electronic parts. Use a tooth-pick for pressing the inductor while resoldering both ends. I used an over-head magnifying glass while soldering these 2 inductors because the size is HALF GRAIN OF RICE, I am talking a very very tiny piece.
Warning: Over heating can damage these inductors. Just in case you damage one of them. You can find a replacemen on a Dell desktop P4 motherboard. Can be found near the 4 pins cpu power (2 black and 2 yellow) for 12v.
It's been almost 3 days now my Westinghouse LCD TV still working fine.
Roan
Triangle Tech Whiz
Posted on Jul 07, 2009
SOURCE: tv will not turn on. power cord is good.
I have a Westinghouse Mod. SK-19H210s that is 16 months old. It would not turn on. Upon investigationg the problem I discovered bad capacitors on the power board. (2200uf and 1000uf). I replaced the components and the TV works great, you can purchase a new power board.
Posted on Jul 13, 2009
  • 4 Answers
SOURCE: westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Posted on Sep 19, 2009
  • 4 Answers
SOURCE: sk-19h210s won't turn on even after 'repair'
Are you sure you got the polarity right when you installed the capacitor? On the one I fixed the negative lead went to the outside of the circuit board but check the diagram underneath.
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
Samsung 13 tv can't get it to run what can I do?
As you and I don't know what the problem is, certain basics have to be first covered. Here is a link describing basics for any TV.
TV Power Light Comes On But No Picture Or Sound
As I don't know if you have an active led power light, here are a couple of videos:
EASY HOW TO FIX SAMSUNG TV NO POWER
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
Samsung TV Won Turn On Has No Power No Standby Light Samsung LCD TV...
If the set is powered up, you can try resetting it to factory defaults. Yes, any of these suggestions may not work but one of them might fix your problem. You might try searching for tips by including the model number in the search. Bear in mind you are dealing with a high voltage device and your next repair may be at the hospital if you are not exceptionally careful.
Feb 28, 2018 | Samsung Televison & Video
I have Samsung UN55EH6050 TV with sound but no picture
check this out..
Samsung power defect causes some TVs to fail and class action suit follows
Watch this video.. ( I did mine - three times - before I bought a LG).. its not hard.. just a little time... the local TV repair shop can install these for you..
watch the + and - sides when installing..
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
Sep 08, 2017 | Samsung Televison & Video
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Problems with Audio and Video cable
there is a switch on the base of the cable labeled HDTV and TV, move to TV for normal cables.
Dec 06, 2009 | Microsoft Xbox 360 Console
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sep 27, 2007 | Sanyo AVM-2506 TV
Westinghouse VR-6025Z 60" LCD TV 1920x1080, 120 Hz, HDTV Logo
107 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
