Question about Oreck pro12 commercial upright vacuum, 12in,8a,120v
Sensor goes off when you hit a wall
Every time you hit a wall or go from carpet to wood floor a sensor goes off. I have to turn it off and then on again. Driving me nuts.
It is probably because you are not supposed to hit the wall with the vacuum you are hitting the power switch which shuts the cleaning unit off
Posted on Mar 21, 2014
Panasonic Dirt Sensor vacuum repair
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
Nov 25, 2017 | Panasonic Vacuums
Can the nimbus 7 in 1 carpet cleaner be used on wooden floors? If so how?.
I would not recommend using a carpet cleaner on wood floors. Too much water can damage the wood.
Feb 03, 2017 | Vacuums
Are the nylon roller carpet cleaners safe to use on laminate wood floors
Why not. Laminate floors are very tough. Just make sure that all of the nylon roller wheels are very free turning and that none have anything embedded in them that can cause possible scratching.
Sep 04, 2015 | Oreck XL Ultra Bagged Upright Vacuum
Just bought a DC33. Multi-floor.It is very hard to push on the carpeting.It is fine on the wood floors.Is there any way to adjust it higher for the carpeting.It is dense carpet not high
There are no floor settings for this unit. Since the brush is spinning, it will create more resistance when running over the carpet.
https://www.dyson.com/support/dc33/dc33-multifloor/flo-dc07-gen-how-to-use-your-dyson/using-brush-control-dc33
Apr 11, 2015 | Vacuums
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Can you advise which setting should be used on different floors, ie hard floors and carpets, theres 2 different settings and I don't know which setting should be used on the different floors
Turn the machine on and look at the bottom. Turn to the two settings. The setting that stops the platten wheel from moving is for hard wood floors. If you cant tell, then setting 1 is most likely for carpets and 2 is for hard wood floors. Your machine is primarily a carpet vacuum cleaner, so 1 should be for carpets.
Feb 03, 2011 | Hoover Vacuums
I bought Roomba 560 robot vacuum cleaner about 3 weeks ago and it has been cleaned without problem all kind of positions of floors (also carpets) Last friday I anyway mountained nearby of outcoming door...
Roomba won't clean black carpet because it interprets it as a cliff. The sensors under the bumper tell the Roomba that it's about to fall down the stairs and it backs away. Unfortunately, because they're a safety feature, they can't be shut off.
Aug 18, 2009 | iRobot Roomba 560 Robotic Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
On/Off switch.
because floor means for lanolium it may have a sensor that detects carpet or linolium
Feb 11, 2008 | Kenmore 35821 Vacuum
Oreck pro12 commercial upright vacuum, 12in,8a,120v Logo
77 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
