Question about Panasonic Televison & Video
No Power It's working and then shut down suddenly. Trying to power it up by manual but it didn't work either. Unplugging it and waiting until next morning to try to power it up again but there is no power at all. Is that the power supply board problem?
  • 35 Answers
Capacitors are blown on the PSB-power supply board inside the set. You can do this fairly cheaply about 20 bucks and that includes a solder iron kit with Flux from radio shack and the thru-hole caps. Caps on the PSB should be completely flat (X)-cap view from top. Not broken at all. Best to replace all the caps on the PSB as some can pop and leak from the bottom as well. Try and get caps only 2V above what you currently have in there as larger ones will be hard to seat and will produce too much voltage and heat and can explode. American made caps or Japanese caps are the best way to go. The China made caps are infamous for going out.. If you don't want to solder the caps on yourself you can pull the board out and take it to a PC repair shop. Then there is always buying a refurbished one online. You need the Parts Rev number off the board to get the correct match.
Posted on May 13, 2014
  • 4234 Answers
SOURCE: NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Posted on May 13, 2008
  • 286 Answers
SOURCE: viewsonic n3251w - no power
A lot of TVs are having their power boards go bad due to a poor brand of capacitor (CapXon usually).
If small problems are noticed with the tv, the solution is to replace the capacitors. However, once the TV gets to the point where there is no power at all any more (not even a stand-by light) then the power supply has to be replaced.
Visit Viewsonic's website or call your local Viewsonic repair shop to get a price on this board. They are usually under $100.
Posted on Nov 26, 2008
  • 44 Answers
SOURCE: Bad power supply and regulator circuit
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
gessneruk
  • 22 Answers
SOURCE: 37"scott lcd tv power supply
We repaired ours for about $5. We have a page with pictures showing the compnents replaced.
Hope it helps!
http://www.findonefindall.com/toyota-sienna/LCT37SHA_Scott_Akai_LG_LCD_tv.htm
Posted on Sep 02, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
Sudden shut down
It's possible that this is a hardware failure or a power adapter failure. Try to reset the unit and reinstall it again. You can also check for firmware updates available online. Try to use other power adapter as well with the same specs with the original power adapter.
Jan 25, 2014 | Linksys Computers & Internet
Windows 7 wont shut down
What happens when you try to shut it down? You can always try Pressing and Holding the Power Button until it shuts down.
If it is stalling when you go thru the normal shut down process then just wait a few minutes then press and hold the power button.
If pressing and holding the power button don't work, remove the power cord, then remove the battery. This will surely work because there will be no power source.
May 06, 2012 | Computers & Internet
Kodak C310 keeps starting up and shutting down
Thank you speters9971- it worked. However, what worked for my c315 is unplugging it and then plugging and then pressing the power and and cancel button at the same time until it turned off and then turned on again. This reset it. Thanks again,
Apr 27, 2012 | Kodak Office Equipment & Supplies
Hp g72-260us suddenly shuts down on battery power only
your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Feb 17, 2012 | HP Audio Players & Recorders
Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Dell truemobile 2300 shows connected to internet, but isn't
When you reset the router, did you first shut the router down, then unplug the modem (wait 30 seconds), reconnect the modem (wait for all lights to go to "normal mode"), reconnect router to power, check for activity light on modem, wait about 30 seconds after all is powered up? If not, try that sequence and let me know if it works.
Mar 05, 2009 | Dell TrueMobile 2300 Router (000001)
Tower intermittently loses power
you need a new power supply !!!!
Jul 05, 2008 | HP Pavilion 754n PC Desktop
Televison & Video Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
