Question about Vehicle Parts & Accessories
Motor specifications for 1999 dodge durango 5.2 rocker arm?
Torque specifications for rocker arms
    Sergeant:
  • 340 Answers
Do you have a Chiltons/Haynes repair manual for this vehicle/motor? The torque specs will be listed under all the specs under engine overhaul. I'd be happy to share, but I have access for a Haynes for 1984 thru 1995 Dodge/Plymouth mini-vans only. And the mini-vans didn't offer the V8 option.
Posted on Mar 23, 2014
Need torque on 1997 chevy tahoe 5.7 rocker arm torque
The rocker arms need to be adjusted, they are not set to a specific torque, they use self locking "crimp" nuts to hold the adjustment, these nuts should not be used over to hold the adjustment replace them.. With the lifters fully "pumped" up tighten the rocker arms to "zero" lash, the turn them in an additional 3/4 turn, you are done.
Feb 21, 2017 | Cars & Trucks
What are the rocker arm torque specs on a 1996 dodge caravan 3.0 liter
Hi Derrel,here's a link to a Autozone repair guide on your rocker arms,you can join their site like me for free and use all their repairs guides,need more help,let me know,k. Repair Guides Engine Mechanical Rocker Arm shafts AutoZone com
Aug 29, 2016 | 1996 Dodge Caravan
Rocker arm torque and sequence for a 1999 grand am 4.3
do you mean 1999 3-4 ! if so the rocker arm bolt torque is 98 and later step 1 is 168 in. lbs. step 2 rotate an additional 30-degrees. no special tightening order. good-day !
Nov 04, 2011 | Cars & Trucks
What are the torque specifications for a 3.5l v6 1995 ford tarus rocker arm
For each valve, rotate the crankshaft until the valve lifter rests on the heel (base circle) of the camshaft lobe. Position the rocker arm(s) over the push rods, then install the rocker arm seats. Tighten the rocker arm seat retaining bolts to 44 inch lbs. (5 Nm).
Final-tighten the rocker arm retaining bolt(s) to 19-25 ft. lbs. (25-35 Nm). For final tightening, the camshaft may be in any position.
Hope helps.
May 19, 2011 | 1995 Ford Taurus
What is the setting on a torque wench for a 97 dodge intrepid with a 3.3 motor to fix the lifters
The torque specifications for the rocker arm shaft bolts is 21 Ft. Lbs or 28 Nm.
Feb 26, 2011 | 1996 Dodge Intrepid
Instructions on changing rocker arm
remove valve cover remove center bolt on rocker arm, it could be a 10mm put new rockerarm in tighten to specification. it could be 15 - 20 ft.lbs. of torque. e-mail me engine size and will email you torque spec tomorrow
Feb 16, 2011 | 1999 Buick Regal
What are the torque specs for the rocker arms on the 86 dodge conquest
The torque specs for the rocker arm adjusting nut is 108-156 lbs-inch (12-18 N-m)
Nov 16, 2010 | 1986 Dodge Conquest
How do you tighten up rocker arms 1999 ford tarus
Locate a repair manual (CHILTONS) <-- is best; and look up the torque specifications.
Once you have located this information, take of one valve cover at a time. With the torque wrench, (engine running) tighten up each rocker arm that is "ticking" or "loose" to the proper torque spec - or until it stops ticking. You will want to work quickly so you don't start to spray oil.
You can torque these with engine off, but start engine with cover removed to tighten them up until they stop ticking.
I suggest also speaking with certified mechanic about this and if there are other certain procedures for this as well. I have personally done it this way (successfully), however, it is always best to get a second and/or third opinion. I have also had a mechanic do this as I watched him as well.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 21, 2010 | 1999 Ford Taurus
Valves tap..are they adjustable ????
The rocker arms on my 99 durango are non adjustable. The lifters are hydraulic units with a hydraulic camshaft.
Jul 16, 2009 | 1999 Dodge Durango
Proper installation instructions for Rocker Arm Installation 1998 Dodge 5.9 360.
locate v8 on crankshaft damper(147 degrees ATDC). rotate engine until v8 lines up with TDC mark on timing cover. install rocker arm and pivot assemblies and torque to 21 ft. lbs. wait 5 minutes before starting vehicle to allow lifters to bleed down correctly
May 19, 2009 | 1998 Dodge Ram 1500 4WD
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
