Question about Starfrit 93209 Rotato Express Electric Peeler
Need to buy replacement blades,
Plastic tabs snapped off,need new ones
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
2006 trailblazer washer wiper nozzle removal replacement
the nozzles just snap in from the top.... you first pop the cover at the pivot point of the wiper arm to access the nut. remove said nut. remove the wiper arms (a puller is very useful to avoid damage) , then Remove the air inlet grille panel (held in with pushpins and small 1/4in or 9/32in bolts. disconnect the hoses and squeeze the two tabs that hold them in. because they snap in from the top, i have seen people crush and brake their old nozzles with needle nose pliers. pull the hose through the hole and attach it to the new nozzle...... NOT the recommended procedure, rent or buy a puller that looks like a small two jaw gear puller to save yourself a big headache (mine was only $45). good luck
Nov 01, 2014 | 2006 Chevrolet Trailblazer
Hi, I have a dell 924 All in one. We bought a new cartridge but it doesn't work. What to do?
many people buy them and forget to remove the plastic tabs. they almost always cause this issue
the tabs are actually rather hard to snap off. and people think they will break them if they snap it off. so they don't get ink out till they actually break the tabs off
your ink should have come with instructions on where t6o break the pesky tabs at.
Feb 18, 2010 | Dell 924 All-in-One InkJet Printer
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
How to replace a circuit board/timer of lg refrigerator lfx25980st, remove the old and putting a new one.
Hi, I will try my best to explain this repair. The light cover inside the fresh food/top section needs to be removed. Grab the light lens on the edge farthest from the door and pull downward. There are 2 tabs that need to be released. Now you will need to use a flat blade and pry the next section off. Start from the front and work you way back. It will appear to be impossible but it will snap off.
Once you get this section free, you will need to loacte the timer board case. It is a plastic box that snaps into place. Good ole plastic right?
PLEASE make sure the refrigerator is unplugged before you replace this board.
I hope this helps you. I just changed one last week and it was frustrating mainly because I thought the plastic was gonna break.
Please let me know if my instructions helped you or if I can assist you furtether.
Vic
Jul 11, 2009 | Microwave Ovens
Offer: multichef for parts
Hi, is this still available? I need the main metal blade to replace mine Cheers Nick
Jun 17, 2009 | Blenders
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
Chrysler mini van'01 wiper blades
Pull them up to standing position for easier to work on. Look on underside for a small tab, you usually push tab, and wiggle & pull blade down & out. New one slides back in same way until it snaps, your done. Do one at a time so you have other for reference, if not sure how it goes back in, it's a little tricky. P.S. Most parts places will install free if you buy them there, just ask.
Mar 08, 2009 | 2001 Chrysler Voyager
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Starfrit 93209 Rotato Express Electric Peeler Logo
331 people viewed this question
Top Starfrit Home Experts
Donni Steen
Tom Chichester
Are you a Starfrit Home Expert? Answer questions, earn points and help others
