Question about Electrical Supplies
Brand new Kohler Cv680 3016 has very weak spark....what would this??
This is on an Exmark later z hp
  • 3,368 Answers
Take it back before you void the warrenty.
Posted on May 30, 2014
The egine runs to fast wih a touch the throttle,what causes that/
does the engine idle when throttling down,if not you may have a worn governor or incorrect spring and or linkage settings.
Apr 22, 2016 | Kohler 20 Hp OHV Command V-Twin Engine...
Safety switch on brake handlechecks ok but motor cuts off when released
check clutch safty switch or seat safty got to be one of those switches
Oct 03, 2014 | Kohler Engines Kohler Command OHV...
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
No spark at plugs after replacing coils it has spark advance what do I look for next
Check for the switching pulse at the coil input terminal. It should be less than the battery voltage but not zero, or pulsing in sync with the engine (if you know the spark dwell angle, you can calculate the voltage by multiplying it by the number of cylinders, dividing by 360 degrees, then multiplying by the battery voltage). If you don't get any indication that the coil is being switched to ground to generate the spark, your distributor contact (for mechanical ignition switches) , magneto or electronic ignition module could be the problem. Before changing whatever one of these you have, double-check the wiring to the coil - a misplaced, broken or loose wire will have the same effect.
Jun 27, 2014 | Kohler 20 Hp OHV Command V-Twin Engine...
Why does 23 hp. Kawasaki exmark mower fuel foul 1 spark plug after you mow a hour
have you tried a different spark plug? if not that then check the ignition coil supplying spark to the plug thats fouling
Jun 25, 2014 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
Kohler command 20 twin engine - no spark
If there's no spark, then either the spark plug has come into contact with gas, or the ignition coil is bad. Try either replacing the spark plugs, or removing the old ones and seeing if the tips are damp.
If replacing them doesn't work or the plugs are dry, then try replacing the ignition coil.
Feb 15, 2013 | Kohler 20 Hp OHV Command V-Twin Engine...
Electrical Supplies Logo
67 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
