Question about Viking Kitchen Ranges
The letters filt are on my timer still after cleaning/remounting the filters. how do i get the message off?
DCWH3042 hood
2 Suggested Answers
  • 41 Answers
SOURCE: I have cleaned the filters,
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Posted on Jan 07, 2011
Do this projector has a filter that can be changed
1,Clean the filter
2,reset the filter timer: menu-setting-used hours of filter-reset the timer
Feb 10, 2014 | Toshiba TDP-T91A DLP Projector
Ice up after a couple hours and need to shut off till melts
One of the main causes for this icing is a dirty or clogged air intake filte. Allow the unit to totally thaw before removing and cleaning the filter. The filter must be completely dry before reinstalling it. Never operate the unit without the filter in place.
Hope this helped you and thanks for choosing FixYa.
Aug 22, 2011 | Heating & Cooling
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Thermostat says check filter,changed filter message still there
all automated ck filter systems use electric eye or vacume to sense the condition of the filter. When you change your filte if it is very dirty make sure you clean the coil also if it is dirty. Make sure that any pickup tube this will be a plastic hollow tube is clean and not obstructed. First try turning the unit off and unplugging it when you plug it back up wait 5 min before turning it back on.
Aug 08, 2010 | Heating & Cooling
How to change carbon filter on whirlpool cooker hood AKG958GY
The paper filte pulls out from under the lugs of the metal panel that is attached to the door, turn the plastic clips on the left and right, half way and it will drop out.
Sep 14, 2009 | Kitchen Ranges
Can't find fuel filte on 2005 camry
I would doubt that your fuel filter is dirty. The car runs better when the injectors are cleaned, as the deposits were removed during the cleaning process that caused poor atomization of the fuel. The fule filter is in the tank, and a really expensive procedure. In short, the fuel filter would be the LAST thing I would change.
Jul 18, 2009 | 2000 Toyota Camry
2004 xl 1200 c.
Have you changed the pipes or air filter, if so go to the next size jet, it wont hurt. You might check the tank filter also, unscrew the petcock,see what the filter looks like!
Jul 04, 2009 | 2004 Harley Davidson XL 1200 C Sportster...
Inlet tube on washing machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 21, 2009 | Washing Machines
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Speed control on fan
It means that the filters on the hood need to be cleaned. You simply pop them out and can wash them in the dishwasher. Once clean, dry and replaced, you hold down the fan speed button (the second button from the left or " - " minus for more than five seconds.) When you first hit the button the A will appear, hold the button when the letter disappears, the timer has been reset until time for the next cleaning. The microprocessor in the system will flash every 30 hours of operation.
May 07, 2008 | Zephyr Venezia ZVE-E30 Kitchen Hood
Kitchen Ranges Logo
66 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
