Question about Acer Aspire One Netbook 8.9" Notebook
Missing registry entries for qualcomm adapter on acer aspire one
I recently followed the troubleshooter on my netbook to fix a problem with my acers wireless ethernet adapter but after uninstalling the qualcomm ethernet adapter, i ran the add new hardware wizard to reinstall the drivers , no luck my computer did not find the drivers anywhere,even after doing a full search in all files. i have tried everything what do i do?
code 19 registry config. incomplete or damaged
    Problem Solver:
  • 13 Answers
Since it appears that you still have your wired connection you need to go here ->
http://us.acer.com/acer-v2/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
to download the Qualcomm wireless driver software. You can then unzip and install the driver.
I would first go into Device Manager and uninstall the wireless driver if it exist to remove any leftover software. Tt should be under the network in Device Manager. If it is not there do not worry about it just install the new driver you downloaded.
Posted on Jun 14, 2009
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
I have an Acer aspire one netbook. As soon as i turn it on, it shows the first screen that is black with ACER on it, but it just freezes there. I can't access the computer unless i press F2 and exit setup....
Looks like there is something wrong with the registry database of your computer. Best way to fix is to clean Windows registry using some reliable software such as Reginout and start your computer normally. Also do the following.
> Limit your startup programs
> Uninstall unwanted programs
> Disable background running services
Thanks
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a built in web cam on my Acer Aspire One netbook that is not working. If the mouse pad works, the camera can't work. how can i have this fixed?
do this Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. and download registry cleaner reg in out may help u
Sep 13, 2010 | Acer Aspire One PC Notebook
Acer Aspire One AOD250 Netbook Built-in Webcam problems....
try this it sometimes works. 1. Start Registry Editor (Regedit.exe). START > RUN > (Type) REGEDIT (and hit ENTER) 2. Locate the UpperFilters and LowerFilters value under the following key in the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F} Write down the upper & lower filter valuse. Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
Feb 18, 2010 | Acer Aspire One AOD250-1924 Netbook
Cd/dvd won't play, fix that with a registry fix
goto majorgeeks.com and look at other registry fix programs , like registry restore
Jul 09, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire netbook has "system not fully installed"error message
There is no easy fix for this. It would need a registry edit to fix it and without having a CD Drive and an XP install CD to boot to, it is pretty much impossible. I would suggest you send it back.
Wish I had better news. Thanks!
Apr 06, 2009 | Acer Computer AOA150 Notebook
Burner won't work with my Acer aspire one netbook
This seems to be going around a lot lately.
If you follow these steps from Microsoft it should fix the problem.
Let me know if you need any other help and please don't forget to rate my solution.
Thanks!
Manually delete the registry entries loadTOCNode(2, 'whattotry'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in WindowsNote Before you use this method, uninstall all CD or DVD writing or recording programs. Deleting the corrupted registry entries might cause problems with any other CD or DVD writing or recording programs that are installed on your computer. Uninstalling these programs before you start will help you avoid any problems that removing the registry entries might cause. You can reinstall these programs after the problem is resolved.
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Mar 01, 2009 | Computers & Internet
Dvd
Try doing this: Step 1: Start Registry Editor
loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
if after deleting the upper/lower filter it still doesnt work try to download the driver for the device and install it.
inform me what happens
francis
Jun 04, 2008 | Acer Aspire 5100-5022 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
i believe it's software problem, you can reload the operating system using alt+f10 or you can try this
http://support.microsoft.com/kb/314060
Feb 16, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
180 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
