Question about GE Tritonr XL GSD6260JCC Dishwasher
How to clean filter in floor of back of dishwasher
Filter seems clogged but I cannot remove the filter
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: GE Profile Dishwasher leaking from the bottom
If your dishwasher is Leaking check the following
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispensergasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case reokace inlet valve
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Use the VOM. God bless you
Posted on Apr 05, 2013
ercupa190
  • 12223 Answers
SOURCE: dishwasher leaks after I cleaned the air pump
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher
Door Seal
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the inlet valve water
Door Latch
The door latched can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Use the VOM, God bless you76c7517c-e034-47da-bf6c-02b58ecb7551.jpg6274586f-de4d-45f0-bbab-ada21592e251.gif
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 25, 2011 | GE 24 in. GSD6200G Built-in Dishwasher
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Dishwasher won't start - I get an F7 message on my ADP5966
Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter
Dec 17, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
The water started leaking on the floor and it is not draining
Hi
Daniel
Nov 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
ADP 7966
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Oct 22, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
F7 fault
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work. The following worked for me: Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Apr 14, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
GE Tritonr XL GSD6260JCC Dishwasher Logo
29 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
