Question about Ozaki Om955-1 Music Powow Bluetooth Speaker, Pink/white
Will not connect to device
New Ozaki om 955 was working fine and pairing with my computer. Quit working after 6 weeks. Works fine with cable that is provided
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
The left one quit working about 6 weeks ago today
Hello! a device called the Tail Light Relay; Located in the under dash fuse/relay box is the likely culprit...It controls the left/right brake lights but not the middle brake light...Also check that the L/R brake lights have a solid ground...Use an ohm meter...Zero ohms to negative battery terminal...
Guru........saailer
Apr 30, 2010 | Pyle Pl1157rd Led Brake Lights Light Bulbs...
I have my second motorola H700 headset paired to a samsung m300 phone. The problem is with my first headset after the pairing of the two, any time the headset was closed the bluetooth icon would go black...
Some phones allow you to set the options for the device in the bluetooth menu for each device. These options include auto authorize which is what you would be looking for to enable for your new headset to auto connect. I'm looking at the Samsung m300 user guide, but it doesn't mention this option, however it may be in the menu as an option when you select the device under the bluetooth menu.
Feb 24, 2010 | Motorola Mobility H700 Wireless Headset
I got new speakers for my laptop, and they don't work!
go to the control pannel, then go to sounds and audio devices, then click the audio tab across the top. under sound playback, choose your speakers as the default device. solution only works like this for windows xp. good luck
Apr 29, 2009 | Ozaki DT-500 3-Piece Speaker System...
RIM 8310 Curve to desktop bluetooth "connection" problem
It seems is something related to this:
http://banagale.com/setting-up-bluetooth-sync-in-windows-xp-using-blackberry-desktop-manager-on-a-dell-d630.htm
I did not try yet, check it if you can an post the results of your tests.
- Ivano from Italy -
Jun 12, 2008 | RIM BlackBerry Curve 8310 Smartphone
Ozaki imini dock
see if you have connected the speaker cable to the right jack i.e the green jack on your pc and raise the volume i the computer if this did not work put some other speakers and play if those speakers works then the problem is with the speakers if even other speakers are not playing then the audio device driver is not instaled on your pc try installing audio drivers which will given to you from *********** board cd if the driver is instaled stil not working it is confirmed that you should buy new speakers or repair it with the product service center
May 10, 2008 | Audio Players & Recorders
Will not pair to phone...Worked fine until today
re: Carmen66. Your advise 'bluetooth' "device is out of range or powered off", worked like magic. Yes, it's a pain to power off the phone and restart it before connecting the bluetooth, but heck it works. Reboot, so simple, inconvenient, but works with GREAT success! Thnk You.Very Helpful. First new phone in a few yrs and was ready to take it all back.
May 07, 2008 | LG enV VX9900 Cellular Phone
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Ozaki Om955-1 Music Powow Bluetooth Speaker, Pink/white Logo
97 people viewed this question
Top Ozaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ozaki Audio Player and Recorder Expert? Answer questions, earn points and help others
