Question about Kitchen Ranges
Kenmore oven/range model 790.45069401; how to remove front mounted control panel
How to remove the control panel mounted at the top front of the unit
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jan 21, 2010
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
SOURCE: Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Posted on Dec 21, 2010
I have Kenmore range model 790.9433. It is showing a F10 code. What does that mean?
Found this on ShopYourWay.com for a model 790.9611. The F10 error code indicates a runaway oven temperature. The only way to reset the range, is to disconnect it from the outlet or go to the main circuit breaker of the home and switch it off for 20-30 minutes, then restore the power. If disconnecting the power for a few minutes does not help, the EOC (electronic oven control) may need to be replaced. Follow these steps to replace the EOC:
Unplug the range.
Remove the rear access panel from the console.
Write down the wiring locations, or a digital camera may come in handy for this.
Remove the wiring being careful not to pull on the wires - pull on the lugs.
Remove the mounting screws that hold the control board in place.
The new board may not come with the overlay (this is the plastic piece the covers the front of the board with all the printing on it. This can be reused. Carefully remove the overlay and place it on the new board.
Install new control board using care not to handle the board components as much as possible.
Reconnect all wiring.
Reinstall back panel.
This may not help you. Sorry. You may have to call a Technician.
Dec 03, 2014 | Kenmore Kitchen Ranges
While oven on range top front is very hot
I do not know the unit but check if the oven vent is near the front. It is also possible the door seal on the top of the door is failing.
Apr 13, 2014 | Kenmore Electric Smooth Top Stove
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
    The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
    May 16, 2011 | Jenn-Air Ovens
    Wall electric oven gets hotter than the tempature reading on the control dial
    If this has a manual turn oven control (not electronic) you will have to replace the oven control thermostat.
    First shut the power off to the oven at the main breaker. Remove the screws holding the front control panel in place. Some of the screws are located inside the oven and some are on top of the control panel. Tilt the control panel forward to access the oven thermostat. While holding the new thermostat in your hand transfer each wire the the corresponding numbers on the new thermostat. Unclip the oven sensor from inside the oven and feed it into the control panel area.Remove the screws holding the old thermostat to the control panel and discard old thermostat.
    Insert new thermostat into the control panel and screw to panel.
    Reinsert the thermostat sensor into the oven cavity and fasten to clips.
    Re assemble control panel.
    WARNING: make sure that no wires are touching when reassembling.
    When everything is back together, turn power back on and test temperature.
    Dec 30, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
    Kenmore Gas range. Oven does not work and F30 alarm displays.
    The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
    This is usually caused by a failed oven temperature sensor probe.
    Replacing this component will likely fix your problem.
    You can order this part from www.searspartsdirect.com website.
    If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
    On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
    Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
    Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
    On some models, you have to remove the lower back oven panel to access the sensor probe.
    If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
    If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
    http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Kenmore stove oven does not shut off
    Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
    Jun 05, 2009 | Kenmore Ovens
    Kenmore gas Range -- Control Panel not working
    Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
    Please rate and god bless:)
    Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I was the two front burners for an extended length of time yesterday on kenmore range. I got an F30 error code and the over will not work nor can I use the timer or the clock.
    Apr 05, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
    Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
    Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
    Kitchen Ranges Logo
    56 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
