Question about Brother CS6000i Computerized Sewing Machine
Brother CS6000i - Needle breaking, bobbin thread not picking up
I am having the same problem.. It worked fine last week, then randomly yesterday it broke the needle when I tried to use it. Went through 4 needles before giving up. I also have tried to clean it out, but nothing works. It is not even picking up the bobbin thread at all. Any solutions?
  • 46 Answers
There are a few possible causes, firstly make sure you have the correct needle and it is in the correct way and make sure when you fit the needle it is pusshed all the way up into the needle holder. If the shuttle or hook is moving around the bobbin case then the timing may have been knocked out. If the it is not moving it means either the gear or belt that drives the hoo / shuttle has been damaged or broken.
Posted on Jul 02, 2009
Why won't my serger make any stitches?
Did you change the needles and then rethread?
Jan 16, 2018 | Sewing Machines
Using my Bernina 440 qe in the embroidery mode needle is hitting the foot.Worked fine yesterday, today I have broke 3 needles.
could you possible have attached a foot that is not the correct one for your Bernina one that is a smaller mm
Mar 03, 2014 | Bernina Sewing Machines
Janomelock jl 603a
try contacting a jamone dealer about the correct needle you need.
Jan 31, 2014 | Sewing Machines
I have a Brother Disney 270D embroidery machine. It has worked fine until last week. I broke a needle - changed the needle as before. Since then, when I attempt to sew a design, the stiches are skipping...
Sounds to me like you may have knocked the machine out of time when you broke that needle and unfortunately its probably something you will have to take in to have fixed. its shouldn't be hard for a trained technician to figure out. One thing you can check is the new needle, the flat part of the needle should be facing away from you. if you put in in backwards it will skip stitches. as far as the screen saying you need to re-thread the needle im not sure what could be causing that. It might have something to do with the machine being out of time. But i would recommend you find a brother sewing machine dealer in your area and have them take a look at it. I hope this helps.
Oct 24, 2013 | Kenmore 15358
Pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Aug 16, 2012 | PfaFF Sewing Machines
Shuttle hook not catching thread
it's possible that when you broke the needle it caused the machine to go out of time & only a sewing machine repair shop can retime the machine
Jan 24, 2012 | Singer Sewing Machines
HI, I ve just got my Juki 644D yesterday. Brand new. Today I was using it and tried to adjust the tension. The front cover was open when I tried to do some stiches to see if the tension was ok. ...
take back the machine to the store you bought it from and get another machine.that is if you have warranty.you will have more problem later on.that needle like metal is from under the machine and it broke off the tension feeder. good luck.
Sep 25, 2011 | Juki MO-644D Mechanical Sewing Machine
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
May 03, 2011 | Sewing Machines
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
454 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
