Question about BenQ MS614 3D-Ready DLP Projector, SVGA 800x600 Resolution, 2700 ANSI-Lumens, 5000:1 Contrast Ratio, HDMI Connectivity
Blurry and smudgy on the whites
Turned on the projector, and the image is weaker, darker and looks a bit blurry. White text is smudgy(looks like water colours). i disconnected it from the computer - and it's the same, so it must be the projector. any idea?
4 Suggested Answers
SOURCE: Projector only displays Black and White / No color images.
The problem is the color wheel. It may have broken or motor stopped on clear. Either way the image will remain unchanged just without color. It will need to be sent in for service. Not an unusual problem for BENQ. I have had 3 that have come apart after making a loud whirring sound. Good luck getting someone with BENQ to help they are horrible when it comes to service. Buyers beware!!!
Posted on Jul 28, 2007
projdoc
  • 2236 Answers
SOURCE: I am having issues with my BenQ PE7700 projector.
if the cables are new, reset the settings to factory default to make sure the resolution matches. if there ia still an issue, replace the main board.
Posted on Nov 12, 2009
charleshucke
  • 1114 Answers
SOURCE: Our church's BenQ projector (PB6240XGA) as of
Here are some troubleshooting steps that may correct the issue you are experiencing with your projector. I have included the link that will take you to the owners manual as well.
http://www.makehackvoid.com/sites/default/files/PB6100_Manual.pdf
POOR COLOR
Try these solutions:
• Select the correct video system.
• Adjust brightness, contrast, or saturation.
BLURRED IMAGE
• Press Auto on the control panel of the projector or the remote control unit to get better
picture quality.
• Adjust the focus.
• Reposition the unit to improve its projection angle.
• Ensure the distance between the unit and screen is within the adjustment range of the
lens.
Posted on Mar 07, 2011
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
The view screan on my Samsung S630 camera is all blurry
Hi Guys
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
Dec 04, 2009 | Samsung Digimax S630 Digital Camera
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
HP 4200 printing very light, smudgy and blurry
Remove the rear door by pulling it down and squeezing the left tab to remove it.
Press the blue hooks and remove the fuser. Look for a worn coating on the gray roller.
Feb 19, 2009 | HP LaserJet 4200 Printer
Sharp DT-100 projector bad picture quality
Hi There Not sure what you visually describe as "blurry" This could be two things - a typical white screen will waste all the definition and brighteness unless you sit in a dark room Our ICE Digital Daytime Screens will take any projector and make the image up to 2000% brighter with a resolution reseolving ability of 20 million pixels. So in this case the definition you are alluding to could be lack of contrast, image definition due to insufficient light from the projector relative to the lux level of the room. Alternatively the lamp could be getting old. The brightness of a lamp falls off rapidly so as you use it more and more the image will become duller and duller contributing to a "blurry" or image lacking in punch etc.
The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally and also the same with our ICE Digital Daytime projection screens. Sharp DT-100 Lamp cost is $US261 delivered. Lamp Code AN-100 http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jan 30, 2009 | Sharp DT-100 Multimedia Projector
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Hitachi 50UX22B
Look inside the lens while the set is on. If you see things floating around inside the glass, the fluid will need to be changed inside of each tube. I will post a link on how this is done if this is a Magnavox TV set. Good luck
Feb 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
T MOBILE MDA VERY WHITE BLURRY SCREEN
Its due to humidity or water. Due to the lack of resources its cheaper or replace than repair.
Feb 13, 2008 | T-Mobile MDA
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
BenQ MS614 3D-Ready DLP Projector, SVGA 800x600 Resolution, 2700 ANSI-Lumens, 5000:1 Contrast Ratio, HDMI Connectivity Logo
Top BenQ Video Cameras Experts
Are you a BenQ Video Camera Expert? Answer questions, earn points and help others
