Question about Maytag MAH6700AWW Neptune Front-Load Washer
What is the delay button for on a maytag front load machine
The delay buttton
  • 957 Answers
It is there so you can delay the wash until late at night when the electric rates are cheeper
Posted on Mar 19, 2014
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
The control lock buttton is on. How do I remove it?
Handyman here-
I had a maytag neptune that did a similar thing. Door would close, but not lock. On the maytag there is 'wax motor' that closes the door lock. Mine melted and would not close. When the repairman came out I noticed a 'wire' that he pulled to make sure the locking mechanism was retracted before he pulled the 'motor'. Perhaps you can find a similar release mechanism to open your door. Note that your machine will not work properly until its replaced.
Good Luck!
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am doing a load of laundry the washing machine maytag neptune
This means locked rotor. you have a bad motor control unit. take the door off by removing the 4 screws also take the side/front panel off. You will see the motor control board. Do you have a delay wash cycle? If you do set it to delay wash remove the jp4 connector if the unit tumbles on it's own then the motor controller is fine but if it does not then you have a bad motor control board. Check it out and let me know. also there is a fuse on that board if you can locate it and check for continuity that will also help diagnose it. MAKE SURE YOU UNPLUG IT FIRST THOUGH!!!!
Jun 04, 2009 | Maytag Neptune MAH6500A Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load GE washer
you just push the delay button once and the light will go off.
Oct 17, 2008 | GE WSXH208A Front Load Washer
Maytag MAH-24 door won't open
sounds like something in pump go there first
Aug 16, 2008 | Maytag MAH2400A Front Load Washer
Front load washer model #WSSH300G0WW
push the button again...... its a toggle button the delay is either on or off.
Jan 21, 2008 | GE WSXH208A Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
