Code for reset circuit
Would like to reset the reset circuit on the circuit board
  • 2,072 Answers
IS this even about a computer?
Posted on Mar 19, 2014
What is f04 Whirlpool 6th sense?
F04 indicates a fault in the heating circuit.
It can be a main board, wiring, thermostat or heater fault.
You would need to check the heater and thermostats with a multimeter to ensure they are not open circuit.
However, the first thing to try is a reset of the control board.
Turn the dial to off.
Turn the dial clockwise to the 6 o'clock position.
Press the start button 3 times
Turn the dial 1 position clockwise.
Press the start button 3 times.
This should erase the code.
Try the machine again.
If the code comes back, you need to check out the heating circuit.
If you change or repair any part, reset the board, then try again.
Jul 09, 2012 | Whirlpool Dryers
Pls can u assist me with the call for service error code C447
Check all your thermistors and heater circuit. Reset the code in 08 400 to zero. Hope this helps
Jul 07, 2011 | Office Equipment & Supplies
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Apr 11, 2010 | Toshiba e-Studio 232 Black and White...
Furnace main fan comes on but the furnace doesn't come on. The indicator red light blinks four times. What does this signify?
You have to get in to the main circuit board. At the bottom of the circuit board it will tell you what the flashes mean, in very small print. Read this print for you codes.
Dec 25, 2009 | Goodman GMS90703BXA Heater
Fault code 01 what is it / how to correct?
HI. Essentially, this code will indicate that there is a serious issue with the main control board. Try to reset this board. This can be done, by shutting off the power for five minutes. You can unplug, or shutdown the appropriate circuit breaker for this length of time. Once the five minutes have passed, simply, re- introduce power to the unit, and try to operate normally. If the error code returns, after the reset, kindly replace the damaged main circuit board.
F-1 Board failure. Replace control board (also called ERC or clock).
Dec 09, 2009 | Whirlpool Ovens
Toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Mar 09, 2009 | Toshiba E-Studio167 Copier
Minolta's DiALTA Color Series CF3102/2002 Service code 1220
Image control board not talking to a main control board, this mite take a while and mite quite costly if you can even fine the board if required to be replaced. First to reset open close front door, if the code comes back, you will have to begin by unplugging machine and removing each connector on each big printed circuit board check each connector on the boars for a bend pin the reseat each connector, next replace boards try site below, could try firm ware update via Konica Minolta Dealer ship they might have access to the secure server for firmware,
Used PCB Circuit Boards for Copiers PCB Assembly Circuit Board Repair
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 23, 2008 | Minolta Office Equipment & Supplies
Konica CF910
You reset the code by pressing the "Trouble reset switch on the Tech Rep setting Switch board, located under the control panel, open the machine front cover its a small circuit board with two small black press type switches (left side switch)
Jun 19, 2008 | Konica Minolta DiALTA CF910 Copier
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
