Question about Kitchen Ranges
Leisure CMTE95C small oven not working, no light, fan or heat?
The small oven doesn't work, no heat, fan or light. Could it be a fuse?
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
  • 833 Answers
SOURCE: electric westinghouse freestyle oven not
This might be a couple of things:
  • Check circuit breakers...there are two that control the oven in tandem. Is one blown open? Turn both off and then on.
  • Check all wiring to the unit. You may have an open wire anywhere in the line including at the terminals in the oven. Make sure breakers are off to do this and all below.
  • Remove the element and check for resistance. There should be some. Also check the element terminals and the plug in the oven for corrosion while you're at it.
  • None of those: the thermostat or over temp sensor might be bad. Find these by looking at the wiring diagram on the back of the stove and tracing out the wiring.
  • Electronics package. Replace if none of the above.
Posted on Jun 16, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
SOURCE: zanussi zce7551x bottom oven not working
The
Posted on Feb 09, 2009
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
May 24, 2014 | Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2010 | Ovens
Neff 1721 0ven element not working??
did you replace both fuses, if its a 240 volt element check the other fuse on the other leg of input power/120 volts + 120 volts = 240 volts
Oct 05, 2009 | Neff U1721 Double circotherm Electric Oven
The main oven has stopped working. The fan works and the Small oven also works.
There could be a few different things wrong. The element may have died. Is the fan you mention the forced air fan? No heat usually means blown fuse or faulty heating element, and since the small oven works I would suspect the the element has blown. You would benefit from getting an appliance serviceman to make a house call to replace the element. Unless you're handy and have a soldering iron, some heat resistant sleeving, and can access the back of the oven comfortably.
Hope this helps. Let me know.
John
May 08, 2009 | Belling DB90 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
