Question about Arrow T50P ARROW STAPLE GUN
Does nothing I was using it with no problems and then it just stopped. makes no sound, does absolutely nothing. there is no jam. I tried it in other outlets and checked my electrical pannel.
  • damon Farenick
    damon Farenick Mar 18, 2014
    The gun is the arrow electro-matic.
My mower isn't getting power but battery is good I was mowing stopped turned it off and now nothing
If the battery passes a load test..then check the battery connections make sure they are clean and if you push with your hand that the connections don't move from side to side or up or down, if they do tighten connections. When you go to start if no lights come on and there is absolutely no sound when you turn the key..Check wires at ignition switch. If there is nothing that lights up, and does nothing, no sound when you go to crank..battery connections is the most likely problem..clean with wire brush and make sure connections are tight.
Sep 19, 2015 | Garden
I had a very bad jam that I thought I cleared, but it won't run. Is there a re-set button?
What is the make and model? What happens when you turn the machine back on? If absolutely nothing you may have blown the capacitor. If it tries to turn but isn't then either the jam still exists or you may have broken some gears.
Or, and hopefully for your sake, the sensors in the paper throat may simply be dirty and need to be cleaned.
Mar 09, 2015 | Office Equipment & Supplies
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Blinker sometimes doesnt work and makes strange sound
Sounds like a problem with the turn signal switch.
Aug 18, 2009 | 2006 Ford F-150
Just stopped working, cannot charge, red light only
It could need a new battery. It doesn't sound like it's holding a charge anymore.
Apr 14, 2009 | RIM BlackBerry 7290
Hp officejet 7110 all-in-one
yes, i resolved the problem. I purchased a new printer.
Apr 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Arrow T50P ARROW STAPLE GUN Logo
80 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
