Question about V-Fit Tornado Air Rower
Loose chain on my v-fit rowing machine
On this v-fit tornado rowing machine followed instructions was told to undo the rope so did that now the chain is completely loose and cant get it back
Meaning of these crochet instructions.ch 2, in first sc (1 sc, 1 hdc, 1, dc), * Will. I make my ch 2 where the parentheses begin or in the single crochet in my last row of a shell
Chain 2 then in the next SC (of the row below), make the combination stitch. So, if the previous row has a bunch of SC, you would make the stitches leading up to the Chain 2. Then Chain 2 and in the next SC, make the 1SC, 1 HDC, ! DC.
Dec 02, 2016 | Sewing Machines
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
I have a Tornado cordless chain saw. I have lost user guide. How do I oil this chain saw?
Google on line and ask for a user manual giving the name, product model number of equipment you are in need of an instruction guide.
Apr 03, 2011 | Tornado CW50 - 91450 Bagged Upright Vacuum
The chain does not return smoothly. The chain does not retract. I don't have a manual to see if the machine is set up correctly.
A return spring or cord is not functioning or broken and the chain sprocket assembly bearing may have become defective or more likely needs lubrication. I would try contacting this company since they sold the product.Fitness Quest Corporate Headquarters
1400 Raff Road SW
Canton, OH 44750
Phone: 1-800-321-9236
Email: Customer Support
Fax: 1-330-479-9213 between the hours of 8:30 a.m. and 6:00 p.m eastern standard time,
Monday through Friday (excluding holidays)
May 20, 2010 | Fitness Quest Integrity 3000 Air Rower
Kettler Model Kinetic S3 Rowing Machine rope snap want spare rope
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:info@kettlerusa.com
Feb 15, 2010 | Kettler Rowing Machine Kadett Rowing...
This is my second wild thing. I wore the first
Hello Ms Weem:
Will the starter cover from your first Wild Thing fit?
Have you looked at the starter cover on a different new Wild Thing (demo)? Is it like yours?
Are you releasing the starter rope with it extended?
Yours is the first problem of this type I've heard for your saw. There is no pulley guide or starter rope thimble I'm aware of. I'd think a small nylon or teflon bushing for the starter rope could be fabricated by a machine shop but it would be at your expense. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The chain has become completely loose and will not recoil, ?
You didn't say what model you have, but I believe they are all functionally similar to my Model B rower. There is a "skewer" assembly inside the seat rail with a shock cord and pulley's that keeps tension in the chain throughout its range of travel. To some extent it is adjustable by taking slack out of the shock cord. On mine, this can be done by grabbing the shock cord adjustment mechanism ("SCAM") with pliers and pulling it out of the rear of the machine and adjusting the slack. If it is very loose or you just want to be sure of what is going on, the entire skewer assembly pulls out from the front (flywheel side) of the seat rail after removing four screws that hold it in place. Go to the concept2 website for diagrams, instructions, and parts lists for your model.
Jan 18, 2009 | Concept2 2 Rowing Machine
V-Fit Tornado Air Rower Logo
62 people viewed this question
Top V-Fit Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a V-Fit Exercise and Fitnes Expert? Answer questions, earn points and help others
