To know if lg ballast replcement has he same function
I AM FROM CARACAS-VENEZUELA, I HAVE LG REAR PROJECTION LG RU52SZ30 THE TECHNICIAN TOLD ME THAT THE BALLAST BOARD WAS BAD I BOUGHT A NEW ONE FROM SHOPJIMMY LG 6913V00002C, THE MANUAL SAID THAT BALLAST BOARD IS LG 6913V00002A, I GUESS THAT I BOUGHT IS IT THE REPLACEMENT ITEM. THE PROBLEM IS THAT THE CONNECTOR IT DOES NOT FIX WITH THE BOARD OF THE LG TV SET. I WOULD LIKE TO KNOW, FIRST IT ALL, IF THE NEW ONE HAS THE SAME CHARACTERISTIC OF THE OLD ONE AND IT CAN MAKE THE SAME FUNCTION. AND SECOND I WOULD LIKE TO KNOW IF IT WORKS, THE TECHNICIAN CAN MAKE CONNECTOR ADAPTER TO PUT THE TV WORKS. I WOULD APPRECIATE YOUR ANSWER AS SOON IS POSSIBLE edgarescobar@hotmail.com
techman
  • 3130 Answers
SOURCE: Samsung SP42W4HPX
The Model number is wrong foir the make, unless this TV is not a US model number. Please double check the model and get back to us.
Posted on Mar 21, 2007
  • 77 Answers
SOURCE: PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Posted on Apr 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
SOURCE: how to replace ballast in toshiba 52hm84 dlp rear tv.
how do I change the lamp?
Posted on May 15, 2009
greenspan
  • 1734 Answers
SOURCE: looking for schematics for RCA P4677OCK Rear Projection TV
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
LG RU60SZ30 I have a LG RU60SZ30. I had a technician come out and I was told I need a new lamp ballast assembly. I was wondering if anyone could help me with this process. I opened up the whole back of tv...
need to unscrew or unclip the board and pull out the back. it will be screwed down to the plastic case. and have the wires plugged into it. remove it all and replace.
Oct 21, 2013 | Televison & Video
I NEED TO REPLACE THE BULB OF MY LG TV RU52SZ30
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which tells you the symptoms of lamp failure, where to get a new lamp and how to do the replacement. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 11, 2010 | LG RU52SZ30 52" Television
Ballast 6913v00002c is a different size than the original
The old and the new parts have same model's of tv and same parts #---.All way fit,if the parts of the tv is one of the main componnents that make the tv work.Talk to ur ventor u buy it from yet?Explain the problems,work somethings out.
Mar 29, 2010 | LG RU52SZ30 52" Television
Solution for tv
Bad Lamp.Or defective Lamp Fan. Encompass Parts 1-800-638-3328
Dec 15, 2009 | LG RU52SZ30 52" Television
Do you have LG lamps available
Here's a link to order a lamp for that model from a major LG parts ditributor:
LG RU52SZ30 Replacement Part Lamp / Bulb
Dec 31, 2008 | LG RU52SZ30 52" Television
Missing LG pedastal
You can find a replacement base stand assembly for that model (42LC7D) at the following link:
LG 42LC7D Replacement Part Base Stand Assembly
Model # RU52SZ30 may have no stand / pedestal available.
Nov 17, 2008 | LG RU52SZ30 52" Television
Blue didcoloration lg ru52sz30
This is a manufacturer defect in the light engine. There is a class action lawsuit that was settled to extend the warranty and cover this repair for FREE. If you call LG with your model and serial number, they should direct you to the extended warranty department and set up the free repair. Details on the settlement are available at http://rearprojectiontvsettlement.com/index.htm.
May 23, 2008 | LG RU52SZ30 52" Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
