Technika led 22-248com: Dvd sound problem
When playing a dvd, the sound goes off after 10 minutes. On re-inserting the dvd, the sound comes back for another 10 minutes then goes off again. There is no sound problem when using the other tv features.
    Sergeant:
    Champion:
  • 266 Answers
Then its not the tv. Your dvd player has a fatal error- the mother board has a problem. You might try a different audio output source but a warm out problem is usually unfixable.
Try another dvd player first, before you go to Craigslist and start over with another player!
Posted on Mar 18, 2014
SOURCE: Technika Pro 19" LCD TV/DVD LCD19DVDID-308
Select the DVD and type 9 7 3 5. This brings up a new menu. Select Region 0. OK.
Posted on Oct 25, 2008
  • 239 Answers
SOURCE: THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Posted on Mar 06, 2009
  • 13 Answers
SOURCE: tv shuts off when you turn it on again it will play a minute
I think this might be bad/swollen capacitors in your power supply, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the PS secondary circuit (may cause the red light blink or shutdown problems).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on we found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Posted on Sep 21, 2009
SOURCE: Technika SC500172 tv/dvd won't come out of standby.
my lcd screen is broken , i need a lcd screen for model no. SC 500172 , can i get it in india, singapore or dubai or anyother place and what is the cost.
Posted on Jan 07, 2010
  • 182 Answers
SOURCE: Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Posted on Jun 11, 2010
Technika manuals
Insert the DVD in the player and it will autoplay.
Aug 16, 2014 | Televison & Video
Screen totally black
Try to play around with the cables as you might have not inserted all the cable properly .
Feb 13, 2014 | Televison & Video
Technika tv/dvd combi dvd will not play when disc inserted it reads then indicats "no disc" and when attempting to play via start control on remote signal "err" appears
your player did not read multi disk or maybe the lens is not clean try to clean it with dvd disk cleaner first or check the disk for some scratches causing problem
May 24, 2011 | Televison & Video
Is there a multiregion hack for Technika HDMISS10 DVD player ?
Technika HDMISS10 HACK. 1.open tray. 2.insert any disc. 3.press set-up. 4.from language menu,select "encoding". 5.press play. 6.select "unicode". 7.press play. 8.press set-up. 9.VERY IMPORTANT!! close draw,press "zero" fast as you can while disc is loading. "not allowed at moment" appears in top right of screen but keep pressing "zero" fast as you can and it will change to "O". player is now multi region.
Nov 27, 2010 | Televison & Video
When playing the DVD player, sounds goes out
Take out all the speaker wires. Then unplug the unit for 30 minutes, come back and plug in all the speaker wires. making sure not a strand is anywhere but in the hole. and then plug back in the unit, This system is good at doing this and then if you do what i said everything is good. Best of luck
Feb 13, 2009 | Panasonic SC-HT900 System
Dvd wont play
http://www.avforums.com/forums/dvd-player-hacks/367355-technika-1030-tesco-value-dvd-player.html
try the link I've copied in above.
it tells you how to change the region to multi region. where you can play ntsc and pal.
We use pal in the uk.
Dec 31, 2008 | Panasonic DVD-S27 DVD Player
Will not play hd dvds
cuse it aint hd dvd ready or blue ray ready ok al it is is a upconvertoing player makes reg dvd look good ok
Feb 02, 2008 | LGDVB418 DVD Player
DVD Freeze-Ups
Sounds like the transverse motor is bad.
Dec 03, 2007 | Samsung DVD-P241 DVD Player
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
