Question about Heartland 3530 Dual Fuel (Electric and Gas) Kitchen Range
Rubber feet for grates - Heartland 3530 Dual Fuel (Electric and Gas) Kitchen Range
How to replace Frigidaire Range model FPDS3085KF Grate Rubber Feet
Hello Friend, I am happy to assist you!
I understand you are looking for instructions on how to replace the rubber grate feet on your Frigidaire range, FPDS3085KF (part number 5304475129). You can do this by removing existing rubber feet. Then clean and remove any residual adhesive. Typically adhesive is provided with new rubber feet kit. Apply adhesive to bottom of rubber feet and install rubber feet on bottom of grate. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). I hope this proves to be helpful to you! - Z
Jun 04, 2014 | Frigidaire FPDS3085KF Stainless Steel Dual...
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. http://www.mdappliance.com/ELX-5304475129.html. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
Also need black rubber feet for GE cooktop grill.
They are available at www.helpfulparts.com.
Referred to as GE Gas Range Cooktop Grate Foot Pad, $1.73 each
Jul 04, 2009 | GE Profile JGP636 Gas Cooktop
KitchenAid Gas Cooktop KGCS105GSS08 grate rubber inserts
no parts available if the rubber u want, or get the tire rubber then cut it wat the size u want coz the tire is more hard compare to the other rubber.
Jun 29, 2009 | KitchenAid 31 in. KGCS105 Gas Cooktop
I am looking for the little rubber feet for the grates of my Kenmore gas range Model 36275980890
Rubber feet for kenmore gas oven range, These are rubber plugs that fit into the bottom of the grate and are shaped like upside down mushrooms. There are 4 of them for each grill. The part number is wb2k101 from sears (special order). Cost is about $5 for a bag of 4 rubber feet.
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Cleaning the cast iron grates and griddle
Take the grates off and slide them on your dishwasher rack and run them thru a cycle... pull them out before dry if you want..
May 31, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Kitchenaid KGCS166 IS MISSING RUBBER PADS UNDERR THE GRATES
I just bought a 16 pack of the WB02T10461 GE replacement feet on ebay for $13 (free shipping). We'll see if they fit, but the pic indicates they should be an good match.
Mar 28, 2009 | KitchenAid 38 in. KGCS166GSS Gas Cooktop
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Dec 31, 2008 | Jenn-Air JGD8345 Gas Cooktop
Replacement Feet
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Feb 18, 2008 | Rival 38601 Smart Pot 6-Quart
Heartland 3530 Dual Fuel (Electric and Gas) Kitchen Range Logo
15 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
